Home > Maintenance & Modifications > Fault Code Help |
Lost comms can be battery issues etc so if has no issues then co not worry |
Thu Feb 15 2018 8:54am |
map_rrs Member Since: 30 Jan 2018 Location: London Posts: 32 |
Thanks for the feedback - think I may not have been as clear as I could have been.
Thu Feb 15 2018 2:33pm |
What are the codes if they had a u in front they can be disregarded most of the time if its a P code thats different can you post them on here |
Thu Feb 15 2018 2:37pm |
Sorry do you have any warning lights on dash |
Thu Feb 15 2018 2:38pm |
Thanks for sticking with me on this - here is the information that you asked for plus some context.
Thu Feb 15 2018 5:11pm |
Have a look here at them as the second one is fuel trim and the 3rd is egr valve so if its smokey you may have egr problems or injector issues
Thu Feb 15 2018 5:21pm |
It would appear you may need to have you injectors checked for balance do you have access to an IID tool or something similar to check |
Thu Feb 15 2018 5:27pm |
Thanks for the pointers.....
Sun Feb 18 2018 2:10pm |
GodivaNige Member Since: 14 May 2016 Location: Warwickshire Posts: 420 |
New injectors are pricey. As a comparison, I had 6 new OEM injectors fitted in my previously owned Touareg by a local VAG Indy and that bill came in at £2200
Sun Feb 18 2018 2:32pm |
Sun Feb 18 2018 5:33pm |
OK, I'm a sort of grown up so time to sort this out...
Tue Feb 20 2018 12:07pm |
IID BT from Gap Diagnostics. The best there is. 2008 MY Java Black TDV8 HSE
Tue Feb 20 2018 12:11pm |
PC76 Member Since: 01 Oct 2017 Location: Northwest Posts: 384 |
I have seen the IID tool read the injector ballencing for the 2.7 engine, this can show worn injectors.. I have had GAP confirm that this isn’t available for the 3.0l variant. |
Tue Feb 20 2018 1:40pm |
Appreciate the feedback -
Tue Feb 20 2018 2:02pm |
