Home > Maintenance & Modifications > Range Rover Sport 2010 onwards DRL modification |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4799 |
The Scandinavian one is not park brake dependent but I think you have the right balance |
Sat Feb 10 2018 8:19pm |
jason-nike Member Since: 08 Nov 2013 Location: sussex Posts: 207 |
Do I need a tool to access CCF settings? |
Sun Feb 11 2018 12:03am |
insiorc Member Since: 17 Jul 2016 Location: Scotland Posts: 533 |
Yes, I have the GAP iiDTool to access the ccf.
Sun Feb 11 2018 12:36am |
So does that just turn on the led marker lights at front plus lights at the back?
Sun Feb 11 2018 1:13am |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4851 |
Out of curiosity I have just checked my MY13 5.0L S/C A/B RRS1 and Pin Number 14 Red and Black wire in the N/S Headlamp Plug Is Definitely a Ignition Live it stays Live with just the Ignition On, with the Engine Running and with the Lights turned on, however it would appear to stay live even with the ignition off until you lock the car and let it go to "sleep", if you unlock it before it has had time go to "sleep" it appears to become live again without the ignition on, quite strange really, but that maybe something to do with switching ignition on and off, same with the lights etc. with headlamp disconnected, as sure it didn't do it when I first tested it, may have got the car confused because I am. Cheers Col Last edited by Col on Sun Feb 11 2018 4:24am. Edited 2 times in total |
Sun Feb 11 2018 2:10am |
I'm pretty sure it's just the same as turning your lights on to dip, but next time out I'll try and remember to double check. I don't do it for looks, I just appreciate meeting cars with lights on whether bright sunlight or dull which proper DRL's are good, this option was a cheap alternative which saved me having to remember to turn on/off lights as I leave it set to auto all the time (the one time I did manually set the lights was when in a queue to board the ferry, I set to sidelights only so not to annoy the car driver in front. Once onboard, tucked up nicely in the bunk, the ships steward phoned the cabin to advise me I'd need to go back down to the car deck to turn off my lights... so I just leave them alone now). Yes the iiDTool is a bit pricey, they pop up occasionally for sale on here but still never cheap. It's been handy for a few things though like checking fault codes, changing the ccf to how I like it etc. 13MY Range Rover Sport Autobiography SDV6 - mine 14MY Range Rover Evoque Dynamic SD4 Black Pack - wife's 99MY Defender 90 TD5, Soft Top Conversion - my toy, and bairns favourite |
Sun Feb 11 2018 2:41am |
Meiang Member Since: 29 Apr 2011 Location: Perth Posts: 389 |
Quote
Sun Feb 11 2018 3:25am |
Looking at wiring diagram it looks like it is all related to the AFS headlights (Dynamic Bending Motor) so if you don't have this option that maybe the reason, could check if there are fuses fitted to position 49 & 50 as these are the AFS one's, might be a case of fitting a fuse and it becoming live, wouldn't know just a thought.
Sun Feb 11 2018 4:10am |
SRE Member Since: 16 Jan 2010 Location: Alicante Prov Spain + Hampshire UK Posts: 2329 |
[quote="insiorc"]Yes, I have the GAP iiDTool to access the ccf.
Sun Feb 11 2018 10:26am |
I looked in the CCF files a couple of years ago at the DRL options, below is a extract from the post I put up then.
Sun Feb 11 2018 10:44am |
You are I have been round this previously, and neither of us remembered As you say only cars fitted with AFS have the ignition supply. Cars without AFS aren't wired, so it isn't just a case of adding fuses. Canadian setting is fine. You won't annoy anybody having the lights go on and off, and you need to select both Park and brake on for lights to go off. |
Sun Feb 11 2018 11:02am |
Well I ordered some flexible drl strips to see what they are like.
Fri Feb 23 2018 4:19pm |
Seepee3o Member Since: 05 Dec 2020 Location: Hogsthorpe Posts: 12 |
Hi Jason, interested to know if you managed to get into your facelift headlights and fit the DRL strips? 2010 3.0 TDV6 HSE Luxury - Santorini Black - First RRS and lovin’ it |
Wed Mar 10 2021 12:21pm |
Ive not had chance to do this yet, I do have some clear dry strips to put in now, but thinking of changing to a 2015 RR so may not do this.
Wed Mar 10 2021 6:51pm |
