Home > Maintenance & Modifications > Range Rover Sport 2010 onwards DRL modification
insiorc
Scotland 2013 Range Rover Sport SDV6 Autobiography Firenze Red
I'd originally been planning fitting DRL's for the safety benefit, but decided to go with changing the settings in the ccf to Canadian. Once the engine is started and handbrake released then the dip lights come one - I'd recon nearly as good as DRL's? Of course they go off if you apply the handbrake at a junction/lights etc. (I can't remember if there's a connection to the Park/Drive aswell), but it never happens at night with having auto lights. 13MY Range Rover Sport Autobiography SDV6 - mine
14MY Range Rover Evoque Dynamic SD4 Black Pack - wife's
99MY Defender 90 TD5, Soft Top Conversion - my toy, and bairns favourite
Post #548187 Sat Feb 10 2018 7:54pm
The Scandinavian one is not park brake dependent but I think you have the right balance Thumbs Up
Post #548188 Sat Feb 10 2018 8:19pm
jason-nike
Do I need a tool to access CCF settings?
Post #548204 Sun Feb 11 2018 12:03am
insiorc
Yes, I have the GAP iiDTool to access the ccf.
After Andy K's post above I had a read to see why I chose Canadian. Scandinavian only works with the lights in the off position, whereas Canadian works in all positions which allows me to retain all auto functions including full beam. Scandinavian would mean manual control of the lights. Where I live it's very seldom I have the handbrake on unless actually parking as the only traffic lights we have on the Island is for roadworks Laughing 13MY Range Rover Sport Autobiography SDV6 - mine
Post #548206 Sun Feb 11 2018 12:36am
jason-nike
So does that just turn on the led marker lights at front plus lights at the back?
Just looked at the tool prices, ouch!!
Post #548207 Sun Feb 11 2018 1:13am
Meiang wrote:
There is no ignition on wires on the plugs which connect to the headlamps on the upgrade L320 as indicated by others (I have tested this in practice). Powerfull UK indicate to use the adaptive cruise loom connection (the picture above is from their website). However this contradicts with their wiring connections list which indicates to use wires which go to the headlamp plugs.
Out of curiosity I have just checked my MY13 5.0L S/C A/B RRS1 and Pin Number 14 Red and Black wire in the N/S Headlamp Plug Is Definitely a Ignition Live it stays Live with just the Ignition On, with the Engine Running and with the Lights turned on, however it would appear to stay live even with the ignition off until you lock the car and let it go to "sleep", if you unlock it before it has had time go to "sleep" it appears to become live again without the ignition on, quite strange really, but that maybe something to do with switching ignition on and off, same with the lights etc. with headlamp disconnected, as sure it didn't do it when I first tested it, may have got the car confused because I am. Confused
Post #548208 Sun Feb 11 2018 2:10am
insiorc
I'm pretty sure it's just the same as turning your lights on to dip, but next time out I'll try and remember to double check. I don't do it for looks, I just appreciate meeting cars with lights on whether bright sunlight or dull which proper DRL's are good, this option was a cheap alternative which saved me having to remember to turn on/off lights as I leave it set to auto all the time (the one time I did manually set the lights was when in a queue to board the ferry, I set to sidelights only so not to annoy the car driver in front. Once onboard, tucked up nicely in the bunk, the ships steward phoned the cabin to advise me I'd need to go back down to the car deck to turn off my lights... so I just leave them alone now).
Yes the iiDTool is a bit pricey, they pop up occasionally for sale on here but still never cheap. It's been handy for a few things though like checking fault codes, changing the ccf to how I like it etc. 13MY Range Rover Sport Autobiography SDV6 - mine
Post #548209 Sun Feb 11 2018 2:41am
Meiang
Australia 2010 Range Rover Sport TDV8 HSE Santorini Black
Quote
"Out of curiosity I have just checked my MY13 5.0L S/C A/B RRS1 and Pin Number 14 Red and Black wire in the N/S Headlamp Plug Is Definitely a Ignition Live it stays Live with just the Ignition On, with the Engine Running and with the Lights turned on"
Definitely no ignition live on wire on Pin 14 on my 2010 TDV8. It may be model dependant, location dependant or options dependant.
Post #548210 Sun Feb 11 2018 3:25am
Looking at wiring diagram it looks like it is all related to the AFS headlights (Dynamic Bending Motor) so if you don't have this option that maybe the reason, could check if there are fuses fitted to position 49 & 50 as these are the AFS one's, might be a case of fitting a fuse and it becoming live, wouldn't know just a thought.
Post #548211 Sun Feb 11 2018 4:10am
SRE
Spain
[quote="insiorc"]Yes, I have the GAP iiDTool to access the ccf.
I think you will find that the reason the lights extinguish when in not in gear/parked etc is purely down to electrical load balance. Imagine in cold weather, Air Con, heated seats, plus head lamps etc and the engine only at idle. Not mush charge if any going into the battery. In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #548215 Sun Feb 11 2018 10:26am
I looked in the CCF files a couple of years ago at the DRL options, below is a extract from the post I put up then.
Have gone into the CCF files and there are three options listed on my car a MY13 A/B 5.0L S/C.
1. DRL Standard
2. Scandinavian
3. Canadian
I activated Standard and all that did was give me two Fault Codes B124A-15 and B124B-15 which are Left and Right Daytime Running Light open Circuit but no working DRL's so it may be when you have either DRL lamp kit VPLSV0064 or 65 fitted you may have to activate this but that is purely a guess. By the way those kit's are over �400.00
De-activated that and then activated Canadian and what that did was nothing with ignition on and Engine Running, however when you engage Drive and let the Park Brake Off it Switched Front and Rear Side Lights and Dipped Headlights On, as soon as you apply P/B and take it out of Drive It switches them Back Off.
Again De-activated that and Activated Scandinavian and what that did was as soon as you Start Engine it Switched on Front and Rear Sidelights and Dipped Headlights.
There is no facility that I could find to just activate the Front Fairy Lights on there own as DRL's.
Post #548221 Sun Feb 11 2018 10:44am
You are I have been round this previously, and neither of us remembered Laughing
As you say only cars fitted with AFS have the ignition supply.
Cars without AFS aren't wired, so it isn't just a case of adding fuses.
Canadian setting is fine. You won't annoy anybody having the lights go on and off, and you need to select both Park and brake on for lights to go off.
Post #548228 Sun Feb 11 2018 11:02am
jason-nike
Well I ordered some flexible drl strips to see what they are like.
Tested how bright they are and are very bright indeed.
They can be fixed around curves etc so are good to go.
Just need to see how to fix them inside headlights to give an original factory style finish
Post #549521 Fri Feb 23 2018 4:19pm
Seepee3o
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Lux Santorini Black
Hi Jason, interested to know if you managed to get into your facelift headlights and fit the DRL strips? 2010 3.0 TDV6 HSE Luxury - Santorini Black - First RRS and lovin’ it
Post #611289 Wed Mar 10 2021 12:21pm
jason-nike
Ive not had chance to do this yet, I do have some clear dry strips to put in now, but thinking of changing to a 2015 RR so may not do this.
Will see how things go.
I did the dry rings on my 2006 RRS I had, fairly easy to do
Post #611311 Wed Mar 10 2021 6:51pm
