Home > Technical > Loose door seal
Pakolainen
Finland 2013 Range Rover Sport 3.0 TDV6 Autobiography Rimini Red
Loose door seal
I have the dreaded left hand side footwell wet. I’ve done all the usual checks and the sun roof drainage channels seem to be fine. I think i read somewhere on here over the past few days about a footwell leakage that came from a broken door seal.
I noticed today that part of my door seal - that connects to the body of the car cones away at one point. Probably a 5 cm area. Would that be a probable cause of water ingress.
I also noticed today that around the same area as the loose door seal - on the inside windscreen there was an area of condensation.
Steve 2019 RRS P400e Autobiography
2014 RRS 3.0 TDV6 HSE Dynamic
2006 RRS 2.7 TDV6 HSe
Alfa Romeo Guillietta 2.0 JTDM 2011
Mazda 3 1.6 2010
Subaru Impreza 2.0 WRX 2005
Post #545319 Tue Jan 09 2018 6:20pm
Eaters
Isn’t there something on here about a leaky windscreen seal as well causing this. Also check your filter behind the glove box for damp IIRC Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #545327 Tue Jan 09 2018 7:39pm
My issue was the seal along the bottom.
Pulled it up. Looked for wet /rust.
Added black sealant to car and refitted.
Post #545336 Tue Jan 09 2018 8:18pm
Pakolainen
ok, thanks for the replies. The footwell is on the driver side (LHD), the passenger side leaked last year but has been fixed and shows no signs of pain yet. The windscreen cowling has been 'loose' for a good while - over a year and hasn't shown to be the problem
The investigation continues. 2019 RRS P400e Autobiography
Mazda 3 1.6 2010
Post #545374 Wed Jan 10 2018 7:18am
Stevepd
And mine was the windscreen scuttle panel leak.
Plastic bottle method to cover the cabin filter corner exposure, sealed the scuttle back with RTV sealant. 2006 2.7 TDV6 HSE in Cairns Blue.
Post #545379 Wed Jan 10 2018 9:21am
