![]() | Home > General (L494) > Restricted performance |
brough74 Member Since: 22 Jul 2017 Location: cumbria Posts: 18 ![]() ![]() |
Last Saturday I had a red warning triangle and restricted performance come on, the car went into limp mode.
Well i hope your garage has more luck than mine, its been in from last Friday till today and the cant find anything wrong with it or get the fault to come up again.
wilf Member Since: 08 Nov 2012 Location: on the naughty step Posts: 759 ![]() |
Must surely be an air leak on the intake side somewhere?
Old Stager Member Since: 12 May 2010 Location: Staffordshire Posts: 116 ![]() ![]() ![]() |
I got the same warning two days ago, but with a yellow triangle and it didn’t go into limp-home mode. AA identified the following fault code/s:System : Engine control - 7M9 / Diesel EDC 17CP11.2 Status :P242A - Exhaust gas temperature sensor (bank 1, sensor 3). Error Message : Malfunction. Error sporadic.suspect temp sensor at fault.
DaveT33 Member Since: 25 Aug 2016 Location: Kent Posts: 5 ![]() ![]() |
I have just had this happen to me today. When I started the car the engine sounded like it was “hunting” although the revs didn’t change. The wife commented that it didn’t sound right. I put it down to the fact it was cold.
IRBails Member Since: 22 Nov 2013 Location: Wollongong Posts: 625 ![]() ![]() |
Buy a Elm Blue tooth OBDP sender and then download a reader app. You will get the engine codes for the issue. These will be basic codes but you should be able to clear faults and see roughly were the issue lies. I have used this setup hem I had my faults some time ago kept me on the road until the parts arrived to fix the issue. M16 SVD 4,4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW. |
In case it helps anyone - mine turned out to be a blocked fuel filter.
Tim in Scotland Member Since: 30 May 2005 Location: Driving along in my automobile Posts: 16065 ![]() ![]() |
I wonder if any of these cars hasn’t been run for while and still have “summer” diesel in their tanks that has waxed up with recent low temperatures. “Winter” diesel is usually on sale from October to April and has anti-waxing additives in it 2018 Melting Silver Mini Countryman PHEV on order for April delivery, bye bye Land Rover after 21 years and 11 LR products..... all because you won’t give me reassurance that should my SDv6 crankshaft break because of a design fault, not MY fault, but the engine builders fault - it will be replaced for free.
Mine had fresh diesel in, but I have been doing a lot of short journeys over the last month or so - maybe that is a factor. Anyway, it’s booked in to have the sensor replaced under the extended warranty, so hopefully that’ll fix it. 14.5MY SDV6 HSE Dynamic Indus silver/lunar/ebony 20" wheels, InControl, full-size spare, electric tow bar, adaptive xenons, adaptive cruise control, auto main beam assist. Gone: TDV8 HSE; Zermatt silver/ebony, 19" off road alloys, active diff, particle filter, tow pack (it was fun) BMW 730D SE (great car, sadly missed). Ford Focus RS mk2, Ultimate green, lux pack 2, bluetooth. The start of my mid-life crisis.
Good reason to carry spare diesel fuel filter. Filters are changed at 50,000 k's according to my last service. Again a simple elm OBD adapter will tell you this and you can change in 10 minutes and be on your way. M16 SVD 4,4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW. |
Site Copyright © 2005-2018 Futuranet Ltd & Martin Lewis
