Home > General (L494) > How to connect a solar panel battery trickle charger to L494
Tim in Scotland
After years of complaining to LR that I could not connect up my £11 Maplin solar panel trickle charger to any of my post 2011 Land Rover products the recent visit by LRA to revive a totally flat battery has revealed the secret of connecting up this sort of charger. Please note these chargers require daylight NOT full sun to work and are intended for long term stored vehicles not those that loose their charge overnight (they have another problem!) and is ideal if you are leaving the car in say an airport carpark for 2-3 weeks or like I do, leave the car on the drive for 3-4 months undriven because I cannot get it near to a power point yo plug in my CTek battery conditioner
Connection is very simple:
A) Open the bonnet and on the left on top of the wheel arch there are two posts (the + is under a plastic cover with a hinged cover) the negative/ earth is adjacent to and in front of that - Connect your cables to these - red to the +, black to the -
B) Land Rover has made some very nice little gaps in the various underbonnet mouldings and seals that enable the cables to be neatly led from the engine bay through the door seals into the cabin
So they become invisible from the outside
C) Inside the car the panel I have has enough cable to either put it on top of the dash or onto of the centre cubby box, however if you don’t have a panoramic roof you will have to use the dash top to ensure enough daylight reaches rhe panel
The panels require amazingly little daylight - I have left them inside a FFRR with the car totally buried under 10cms of snow cover and the little blue charging light can still be seen winking away! On my Defender which is in a large agricultural shed with very dirtying clear corrugated Perspex roof windows there has been enough daylight that this morning after 3 months hooked up the defender started 1st turn of the key.
It is also possible to connect direct to the battery which is in the car’s boot, under the suspension compressor, but to get at the terminals may require removal of the compressor to open the + terminal cover (that was what LRA was going to try but there was the problem that with a flat battery you cannot open the powered tailgate or the glovebox..........) 2018 Melting Silver Mini Countryman PHEV on order for April delivery, bye bye Land Rover after 21 years and 11 LR products..... all because you won’t give me reassurance that should my SDv6 crankshaft break because of a design fault, not MY fault, but the engine builders fault - it will be replaced for free.
2015MY Corris Grey SDv6 HSE Dynamic, but not for much longer........
Post #538791 Fri Oct 20 2017 11:22am
riverblanche
Hi Tim,
glad you put the pictures of the engine bay to door Thumbs Up
I have in the past used the tow socket to charge (bike optimate) but new car, although has tow gear I have re-fitted the original rear panel so can not easily access the tow socket Rolling Eyes
I have connected to the "pegs" under the bonnet but thought the gap in the rubber seal just allowed the cable to pass outside the bonnet, not as your pics to be concealed
Thumbs Up Corris HSE Dynamic 2016
Always pick up stick in the middle !!
Post #538826 Fri Oct 20 2017 9:14pm
Johnski
Was there a specific reason to move battery to boot after L320 model? Or is it a extra one for stop/start use? Question Bow down John
Post #538834 Fri Oct 20 2017 11:01pm
Tim in Scotland
It is the main battery and I have no idea why it was moved other than a guess that there wasn’t enough room in the engine bay? I do think that moving the suspension compressor into the boot was a good idea - at least now it is away from the wet and road dirty so filters etc won’t (hopefully) clog up so easily, and it is inaudible inside the car too yet there is only the boot floorboard that covers the spare wheel to insulate the cabin from any noise when it is running. 2018 Melting Silver Mini Countryman PHEV on order for April delivery, bye bye Land Rover after 21 years and 11 LR products..... all because you won’t give me reassurance that should my SDv6 crankshaft break because of a design fault, not MY fault, but the engine builders fault - it will be replaced for free.
Post #538836 Fri Oct 20 2017 11:12pm
Tim in Scotland
Oops double post 2018 Melting Silver Mini Countryman PHEV on order for April delivery, bye bye Land Rover after 21 years and 11 LR products..... all because you won’t give me reassurance that should my SDv6 crankshaft break because of a design fault, not MY fault, but the engine builders fault - it will be replaced for free.
Post #538835 Fri Oct 20 2017 11:12pm
adameverett
Never understood why they put the air compressor on the out side, open to damage and the elements. My brother-in-laws 2004 vogue the air compressor's in the boot, and 10 mins to service and remove the unit for maintenance.
Post #538840 Sat Oct 21 2017 7:13am
espaceboy
United Kingdom 2013 Range Rover Sport 4.4 V8 Autobiography Adriatic Blue
you could plug solar panel it to the rear aux socket and avoid croc clips and in the in car cable routing.
you just need to make the rear aux socket perm live by removing and jumping the aux relay.
the solar panel can then sit on the parcel shelf and then its cable routing is easy and well hidden.
Note. Its not unknown for the diode to fail short circuit (sc) in the solar panels when subject to higher opposite alternator voltage, if the fail s/c the solar panel can drain the battery very quickly.
So best to disconnect the panel before starting the car!
another reason why you are far better with a battery maintainer and charge the car up right up before long periods of rest/parking.
the drain current on the l494 seems to very low compared to previous land rovers so sitting for weeks should be easily achievable on a good full charged battery
Post #538860 Sat Oct 21 2017 1:31pm
Tim in Scotland
Not sure how to re-enable the rear socket but also I have privacy glass which reduces the amount of light getting to the solar panel. 2018 Melting Silver Mini Countryman PHEV on order for April delivery, bye bye Land Rover after 21 years and 11 LR products..... all because you won’t give me reassurance that should my SDv6 crankshaft break because of a design fault, not MY fault, but the engine builders fault - it will be replaced for free.
Post #539736 Mon Oct 30 2017 9:38pm
Johnski
Tim in Scotland wrote:
It is the main battery and I have no idea why it was moved other than a guess that there wasn’t enough room in the engine bay? I do think that moving the suspension compressor into the boot was a good idea.
Thanks a lot Tim, for taking time to reply to my query. Thumbs Up John
Post #539740 Mon Oct 30 2017 10:03pm
scrumps
United Kingdom 2013 Range Rover Sport SDV6 HSE Baltic Blue
I did exactly this on our 16MY A/B while on a recent 3 week holiday to the USA.
Dis-connected in the Heathrow car park before starting - no problems.
Scrumps Somerset - Where the apples do grow and the cider do flow!
17MY D5 3.0 HSE - Firenze Red.
16MY SDV6 AB -Aruba Silver - In the drive!
13.5MY SDV6 "HSE Black" - Baltic Blue - Gone and sadly missed.
10MY TDV8 HSE Galway Green - Gone
14MY D4 HSE in Scotia Grey - Gone
05 TD5 D90 CSW in Cairns Blue
Post #540063 Fri Nov 03 2017 11:54am
Tim in Scotland
Oh yes it’s really important for your solar panel not to start the car with the panel still connected............ not good for the life of the electronics in the panel! 2018 Melting Silver Mini Countryman PHEV on order for April delivery, bye bye Land Rover after 21 years and 11 LR products..... all because you won’t give me reassurance that should my SDv6 crankshaft break because of a design fault, not MY fault, but the engine builders fault - it will be replaced for free.
Post #540065 Fri Nov 03 2017 12:38pm
RR Ally
I have just bought an AA branded solar panel trickle charger as it the only one i found that connects to the OBD port inside the car. This saves all the messing about running wires when you get to the airport car park.
I have left the car for 2 plus weeks at the airport and it was fine, just goggle AA solar charger for details, or follow the link below:
https://shop.theaa.com/store/home/car-battery-solar-charger
Happy charging
Post #542853 Thu Dec 07 2017 12:07pm
Tyrefitter
United Kingdom 2013 Range Rover Sport Supercharged Autobiography Fuji White
I was looking at these at local motor factors £15 plus vat which is a good price if it works & easy to plug into obd.
Andy 2014 RRS SC santorino,coris roof.
2016 VW Amarok Highline,candy white
2014 Evoque D-Lux Fuji
Previous motor.
2014 RRS AB FUJI
2012 RRS Dynamic red edition Fuji
2012 RRS SE santorino
2015 Navara White
2008 RRS white TDV8
2007 RRS black TDV8
2002 RR Vogue
1996 P38 2.5 HSE.
Post #542861 Thu Dec 07 2017 2:44pm
Dave777
Assuming you can find the OBD port now!!! MY16 3.0 SDV6 Autobiography in Aleutian silver, stealth pack and toys.
Post #542891 Fri Dec 08 2017 1:44am
Site Copyright © 2005-2018 Futuranet Ltd & Martin Lewis
