Home > General (L494) > How to connect a solar panel battery trickle charger to L494 |
Hi Tim,
Fri Oct 20 2017 10:14pm |
Was there a specific reason to move battery to boot after L320 model? Or is it a extra one for stop/start use? John
Sat Oct 21 2017 12:01am |
It is the main battery and I have no idea why it was moved other than a guess that there wasn’t enough room in the engine bay? I do think that moving the suspension compressor into the boot was a good idea - at least now it is away from the wet and road dirty so filters etc won’t (hopefully) clog up so easily, and it is inaudible inside the car too yet there is only the boot floorboard that covers the spare wheel to insulate the cabin from any noise when it is running. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Sat Oct 21 2017 12:12am |
Oops double post 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
adameverett Member Since: 14 Nov 2015 Location: Warwick Posts: 110 |
Never understood why they put the air compressor on the out side, open to damage and the elements. My brother-in-laws 2004 vogue the air compressor's in the boot, and 10 mins to service and remove the unit for maintenance. |
Sat Oct 21 2017 8:13am |
espaceboy Member Since: 13 Aug 2017 Location: Fife Posts: 28 |
you could plug solar panel it to the rear aux socket and avoid croc clips and in the in car cable routing.
Sat Oct 21 2017 2:31pm |
Not sure how to re-enable the rear socket but also I have privacy glass which reduces the amount of light getting to the solar panel. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Mon Oct 30 2017 10:38pm |
Thanks a lot Tim, for taking time to reply to my query. John RRS MY12 SDV6 HSE. Sumatra Black/Ebony & Walnut + Dynamic Pack, + Cold Climate Pack + Memory Pack, Digital TV/DVD, Premium Leather, Cornering Lights, Cooler/Fridge Box, & most Options. |
Mon Oct 30 2017 11:03pm |
scrumps Member Since: 01 Aug 2011 Location: Somerset Posts: 452 |
Fri Nov 03 2017 12:54pm |
Oh yes it’s really important for your solar panel not to start the car with the panel still connected............ not good for the life of the electronics in the panel! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Fri Nov 03 2017 1:38pm |
RR Ally Member Since: 28 Nov 2015 Location: Kings Lynn Posts: 48 |
I have just bought an AA branded solar panel trickle charger as it the only one i found that connects to the OBD port inside the car. This saves all the messing about running wires when you get to the airport car park.
Thu Dec 07 2017 1:07pm |
I was looking at these at local motor factors £15 plus vat which is a good price if it works & easy to plug into obd.
Thu Dec 07 2017 3:44pm |
Dave777 Member Since: 15 Feb 2015 Location: Sussex Posts: 485 |
Assuming you can find the OBD port now!!! MY16 3.0 SDV6 Autobiography in Aleutian silver, stealth pack and toys. |
Fri Dec 08 2017 2:44am |
