Home > General > Tap Tap Tappity Tap |
GodivaNige Member Since: 14 May 2016 Location: Warwickshire Posts: 420 |
Tapping was probably a chunking stone trapped in your tyre tread. |
Tue Oct 31 2017 11:51am |
Stone caught in the tread and/or between backplate and disc?
Tue Oct 31 2017 11:54am |
Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1048 |
Hmm... Might have been. Tap did sound more mechanical than stone road noise though, it was a solid tap. I thought drive-shaft initially. I do have AT tyres and there are a lot of stones around here. |
Tue Oct 31 2017 12:07pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4799 |
not compressor then ? |
Tue Oct 31 2017 1:01pm |
Does compressor make that noise? No errors on dash but I'll check IID
Tue Oct 31 2017 2:34pm |
Have you been off-road lately? 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Tue Oct 31 2017 3:06pm |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8850 |
Rear prop shaft centre bearing? 2012 SDV6 - it's missing a couple of cylinders
Tue Oct 31 2017 3:09pm |
Pay n play a few weeks back and I had to go gently into a muddy field (low range, mud rut) on Saturday night to winch my tractor out again. Set everything back |
Tue Oct 31 2017 3:52pm |
Could be that start of the EPB shoes getting filled up with crud! Sounds like similar symptoms to when my EPB failed. 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Tue Oct 31 2017 4:19pm |
Sound Clip
Tue Oct 31 2017 4:26pm |
Well from previous experience I think we can rule out the stone stuck in the tyre tread or something stuck in the dirt guard around the brakes. When I have had something stuck in the Defender’s dirt guard it has been more of a squeal than a ticking noise. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Tue Oct 31 2017 6:41pm |
Maybe a big stone hitting the inside of the wheel as it goes round? Though all the stones round here are pretty soft |
Wed Nov 01 2017 10:42am |
That's not a stone, have you checked the rear drive shafts for reeds or anything wrapped round them ?
Wed Nov 01 2017 1:40pm |
Well...
Fri Dec 08 2017 4:07pm |
