Home > General > Steering Wheel Wobble |
Sounds to me as though you have a buckled wheel.. |
Fri Oct 06 2017 10:57am |
Did you swap sides or front to rear ? |
Fri Oct 06 2017 10:55pm |
Chunk11 Member Since: 02 Jul 2017 Location: Manchester Posts: 47 |
I don't know as the only way I could tell was that one wheel had a very small kerb mark on and that is how I know it ended up on the wrong side after the first trip to the garage. The other wheels, they have no distinguishing features, I have no idea if they were front/back or side to side or both.
Mon Oct 09 2017 8:25pm |
It depends where you were feeling the vibration, if it was through the steering wheel then moving the buckled wheel to the rear of the car will pretty much hide the issue (if this is the case, when it was on the front you only felt the vibration through the wheel), if you have directional tyres fited and they're running the wrong way they MIGHT cause vibration, but I would doubt it.
Tue Oct 10 2017 1:45pm |
