Home > In Car Electronics > Head unit and nav |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4789 |
Not unknown.
Tue Oct 03 2017 9:24pm |
Cosmo15555 Member Since: 24 Jun 2014 Location: Stevenage Posts: 163 |
I have just checked faults and this was in system
Tue Oct 03 2017 10:11pm |
Sounds like you have messed up the ccf if you go into the IDD tool and find the save/restore part and restore the original file that was saved when you first plugged it in it should return the car to its original state or your amp.most circuit may have a fault |
Wed Oct 04 2017 8:10am |
The stereo was doing this before I connected the iid tool in but thanks for the suggestion |
Wed Oct 04 2017 8:55am |
Sounds like maybe the amp or can you do i hard reset first as it’s simple it is explained in the wiki |
Wed Oct 04 2017 9:00am |
d-9 Member Since: 10 Jan 2017 Location: Herefordshire Posts: 299 |
Start off by disconnecting the battery for 10s or so. Mine used to do that until I replaced the battery. Sat nav screen would freeze on the LR logo too. |
Wed Oct 04 2017 11:07am |
I tried disconnecting the battery but didn’t sort out problem then I disconnected the battery an joined the cables together with jump lead then reconnected live then earth but still the same
Wed Oct 04 2017 10:08pm |
I spoke to a car audio Center today they said could be amp or even Bluetooth module
Thu Oct 05 2017 5:57pm |
I guess their concern is that the optical network is broken, so the sound doesn't get to the amp.
Thu Oct 05 2017 6:02pm |
I’ve tried 2 different phones that are paired with the module but neither will connect with it |
Thu Oct 05 2017 8:26pm |
You can get an optical loop off for a couple of quid to disconnect the Bluetooth And see if sound is restored |
Thu Oct 05 2017 9:31pm |
Thanks for reply 👍 |
Thu Oct 05 2017 9:52pm |
scarey Member Since: 07 Jan 2011 Location: in the cloud Posts: 410 |
this is for the L322 but the same applys to yours,
Fri Oct 06 2017 8:35am |
So the FF owners use a Biro |
Fri Oct 06 2017 3:34pm |
