Home > General > Suspension fault and yellow warning light
Nico2104
Just been sitting waiting for my children to finish school when a beep happened and it came up with suspension fault and the suspension light went yellow. It then dropped the back rear corner down but then without touch anything the light went off and suspension went back to how it should be. I left the car running and a few minutes later the exact same thing happened so I had a look at the 4x4 screen and the rear driver's side wheel was going up and down. Am I right in thinking this could be a dodgey ride height sensor. I will out a picture of what the screen looked liked. Any advice would be much appreciated.
Post #535772 Mon Sep 18 2017 3:20pm
Nico2104
Sorry forgot to mention it's a 2005 rrs 4.2 supercharged
Post #535773 Mon Sep 18 2017 3:20pm
Nico2104
Post #535774 Mon Sep 18 2017 3:21pm
Nico2104
Any help would be appreciated. Thanks
Post #535926 Tue Sep 19 2017 9:49pm
Johnski
I can't help you, but a bump to bring to the attention of others. Smile John
Post #536185 Fri Sep 22 2017 6:55pm
geoffsnook
ohh it could be but then it is a land rover get a code reader or get someone to look at the codes could be valve block suspension bag ride height sensor or a wiring fault or a few other things Thumbs Up
Post #536193 Fri Sep 22 2017 7:31pm
DrRob
Get codes read Thumbs Up Visitor from fullfatrr.com
* Current: 2011 4.4 TDV8 Full Fat. Amazing piece of kit.
Post #536204 Fri Sep 22 2017 9:03pm
Nico2104
I am having the codes read next week but it hasn't done it since I posted which is strange. Literally 5 minutes of it beeping and doing what it did in the picture but then fine once driving and never happened since.
Post #536207 Fri Sep 22 2017 9:26pm
If it happens again it's important to remember the order.
If it bongs and then the suspensions physically goes down I would guess a sensor.
Post #536225 Sat Sep 23 2017 8:11am
Nico2104
It definitely boinged 1st and then the rear driver's side went down. I might just change the ride height sensor as there not expensive or hard to replace so might be worth just replacing and clearing all faults. Cheers
Post #536229 Sat Sep 23 2017 8:32am
geoffsnook
Well it is a Land Rover after all Rolling with laughter
Post #536230 Sat Sep 23 2017 8:34am
Trouble is they need calibrating so maybe best not to mess with it.
Post #536232 Sat Sep 23 2017 9:07am
squizzel
United Kingdom 2005 Range Rover Sport TDV6 HSE Arctic Frost
Are they not like the P38 and D2 ride height sensors, if you don't disconnect the battery and change the sensor, then they have to be calibrated. Disconnect the battery, change the sensor and then reconnect the battery and the system is no wiser , just picks up the sensor.
Post #536237 Sat Sep 23 2017 9:55am
don't know.
Post #536238 Sat Sep 23 2017 10:05am
Nico2104
I have a fox 910 diagnostics which does calibration on the suspension and other stuff so I think I might change it and then calibrate it myself. Then it will just be a waiting he to see if it does it again. Cheers
Post #536245 Sat Sep 23 2017 2:53pm
