Home > Technical > Electronic Park Brake issue.
Page 2 of 3 <123>
geoffsnook
Not on the early ones i can leave mine in park and the hand brake does not come on but if i put it on a can drive away and it does release without pressing the button but on my manual disco 3 it came on as soon as i turned off the key Thumbs Up
Post #535497 Fri Sep 15 2017 6:44pm
GodivaNige
It is true that lack of use will likely give problems with electronic hand brakes, use it or lose it as the saying goes. My 2009 3.6 doesn't apply the brake when in Park so maybe this is a later mod?
If the car has been parked up for months without use of the brake then this is contributing to your problem, the issue is, whilst regular use from now on may cure the problem, you don't know if in the meantime, the brake could seize on or damage the EPB module.
The best thing to do is have a service done asap on the brake after which, use it regularly. Until you get the service done, don't use it because there's a chance it may seize on at THE most inconvenient time.
I leave mine off when parked on my flat level drive, but regularly use it when driving
Post #535498 Fri Sep 15 2017 6:57pm
Cymruambyth
Wales
Thanks for the replies chaps Thumbs Up Not sure I`d need a fuel burning heater though Laughing Steve.
Post #535501 Fri Sep 15 2017 7:03pm
geoffsnook
They are good fbh's but petrol's to warm up a lot quicker than diesel's Thumbs Up
Post #535512 Fri Sep 15 2017 7:35pm
gogsy1956
Just to backup most of the other replies,, my handbrake started squealing slightly a couple of days before we went on holiday,,, on the morning we were leaving it sized good style,, even the emergency release wouldn't work. Had to get it lifted to my indie while we were away. Just cost me for new module, discs, pads and shoes etc as they couldn't get the discs off even after cutting the cables. I was told I should make a point of taking the discs off at each service and have everything cleaned up as the build up of brake dust etc causes no end of troube 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #535557 Sat Sep 16 2017 8:09am
Cymruambyth
Wales
Did it again briefly today, not done it for a day or two. I`ve been told again that it`s probably due to lack of use. I`ve pm`d Bodsy a couple days ago, just waiting for a reply. Steve.
Post #535787 Mon Sep 18 2017 5:27pm
DrRob
Bodsy will sort it Thumbs Up
Might be worth asking him to give it the once over whilst he's with you Thumbs Up Visitor from fullfatrr.com
* Current: 2011 4.4 TDV8 Full Fat. Amazing piece of kit.
Post #535789 Mon Sep 18 2017 5:31pm
Cymruambyth
Wales
I will do if he gets back to me Thumbs Up Steve.
Post #535790 Mon Sep 18 2017 5:33pm
gogsy1956
Get the rear brakes serviced as soon as poss,, it's looking like they are about leave you with a large bill! 2010 RRS, TDV8
22" overfinch
Post #535801 Mon Sep 18 2017 6:14pm
Eaters
See here.
https://www.carkeys.co.uk/guides/things-to...ic-gearbox
I have got into the habit of putting the EPB on whilst in neutral, then releasing the footbrake to ensure the car is held by the EPB, then selecting Park.
First it ensures that there is no strain on the gearbox, and second I'm using the EPB regularly so hopefully avoiding risk of seizing.
The alternative could be (1) an expensive gearbox repair to find a sheared off pin that's rattling around inside, and (2) not having to find the cost of repairing whatever the 2.5 tons of RRS uses to stop if the pin fails and the EPB wasn't used. Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #535842 Mon Sep 18 2017 11:34pm
Cymruambyth
Wales
Good advice, thanks. I was actually told that today, apply epb whilst in neutral....then select Park Smile Steve.
Post #535844 Mon Sep 18 2017 11:42pm
gogsy1956
Well,,, to be honest I think no matter which way you apply the handbrake or not use it some of the time unless you remove the discs annually and physically clean, lubricate and adjust correctly it will eventually sh*t it's pants!! 2010 RRS, TDV8
22" overfinch
Post #535859 Tue Sep 19 2017 8:08am
Cymruambyth
Wales
Just done it again this morning when I got to work. Need to get searching and find a decent garage local to me and get it sorted. Steve.
Post #535961 Wed Sep 20 2017 9:57am
geoffsnook
Quicker the better you get them adjusted and cleaned the cheaper it will be in the long run Thumbs Up
Post #535964 Wed Sep 20 2017 10:01am
Cymruambyth
Wales
Yeah, as soon as I find a place I`ll get it sorted Thumbs Up Steve.
Post #536004 Wed Sep 20 2017 5:22pm
Page 2 of 3 <123>
