Home > General > Suicidal hesitant set off. Cured!! |
shepp Member Since: 15 Nov 2010 Location: Bingley Posts: 440 |
Hello all
Thu Aug 24 2017 2:28pm |
Danv8 Member Since: 20 Apr 2015 Location: Norfolk Posts: 378 |
if you go through euro carparts and put in the SAVE30 code you get 30% off which brings it down to within 40p off this price but its free delivery. |
Thu Aug 24 2017 3:30pm |
Euro carparts I would never deal with these clowns again,,they supply crap parts & are usually wrong when we receive them.
Thu Aug 24 2017 3:43pm |
I had a 64000 mile service a week after, including gear box and transfer box oil, but the major difference was due to the cleaner. I've only had the motor since January and hated it ever since, until now. The torque figures didn't add up, as I was always pushing the vehicle to move. I generally drive very steady, which is usually easy with a vehicle with high torque. The fuel treatment has transformed the big girl. I even used BP premium fuel since I got her in January, which made little difference. Now especially after spending a small fortune on service and all drivetrain oils, she is feeling very refined. But to the fuel treatment, first time evet one of the snake oils has worked for me MY12 RRS HSE Gone 4.2 supercharged RRS Gone 90 Gone s2000 |
Thu Aug 24 2017 5:55pm |
Puslinch Member Since: 08 Jan 2017 Location: Surrey Posts: 192 |
Mine does the same at times, annoying...for 12.00 worth a try! Thx for the tip.... 2018 Telsa MS
Fri Aug 25 2017 11:31am |
RRSRobC Member Since: 31 May 2017 Location: Laleham, Surrey Posts: 23 |
Forgive me if it's a stupid question but how does this work? I'm not finding my car sluggish but it is 10 years old and for £12 it's worth seeing if it will make any difference... 2007 L320 3.6 TDV8 HSE Java Black
Fri Aug 25 2017 12:32pm |
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2007 |
https://www.wynns.eu/product/diesel-extreme-cleaner/ Visitor from fullfatrr.com
Fri Aug 25 2017 5:03pm |
For the minimum amount required for a tank full of Diesel, one bottle isn't enough for it to do it's job properly,and if you have a bad problem, or not cleaned engine/injectors EGR for a while, they recommend 1x500 size bottle for each 30 litres of diesel fuel, they recommend the tank should be filled with fuel when you use this product, not cutting fuel amount in tank to save money and put in less product, it doesn't work to its full potential.
Sat Aug 26 2017 12:12am |
Duplicate post please delete.
Sat Aug 26 2017 12:13am |
I used the Wynns injector cleaner over 3 tanks of diesel on my Defender and now do that annually and there is a noticeable improvement in performance. The car is 21 years old but only 88000 miles on the odo. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Sat Aug 26 2017 7:54am |
On the bottle it says 1 bottle to 60 litres, but can use it 1 to 30. I added it to approx just less than 3/4 of a tank. For me it worked very well. I also added it just before a 60 mile motorway journey. MY12 RRS HSE
Sat Aug 26 2017 7:58am |
I assume the mis fuel device doesn't get tripped by it ? Visitor from fullfatrr.com
Sat Aug 26 2017 4:09pm |
Gearbox oil is due at 10 years on standard LR schedule. Have you changed it early? Visitor from fullfatrr.com * GONE. 2012 RR Sport HSE SDV6 Orkney Grey. Now being piloted by RRSTDV8 * Current: 2011 4.4 TDV8 Full Fat. Amazing piece of kit. * Current. 1974 Lightweight 2.25L petrol. Old skool * GONE. Freelander GS TD4 Manual MY2013. Orkney Grey with privacy, cold and clearview packs, armrests (a must!) and a spoiler. * GONE. Range Rover Classic '93 200Tdi Factory fit * 1949 80" in family since 1975 |
Sat Aug 26 2017 4:18pm |
I did change it early. My old sc suffered drive line shunt and wasn't as smooth as it could be at 100k. So decided to change the gearbox oil earlier to try prevent any damage. Oil for life does not exist as yet. Apparently my transfer box oil was fairly cooked but I had that changed, and just been lazy I had both the diffs done.
Sat Aug 26 2017 7:39pm |
