Home > Maintenance & Modifications > Battery drain |
Guyzer73 Member Since: 04 Jul 2009 Location: Muscat Posts: 852 |
Brief update, checked voltage this morning and it's 11V across the terminals... 2006 RRS S/C CONSTANTLY under modification...
Sat Aug 12 2017 6:25am |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4799 |
Alternator?
Sat Aug 12 2017 8:00am |
Hi Andy,
Sat Aug 12 2017 8:19am |
Common drain is the rear tailgate handle switch. Bodsys Brake Bible
Sat Aug 12 2017 8:11pm |
Cheers Bodsy,
Sun Aug 13 2017 6:03am |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4851 |
That's the same rated battery my 5.0L S/C had from new, the petrol one's seem to be lower rated than the diesel spec. ones. I actually replaced mine with a Varta AGM Stop/Start battery I think it was type G14 whatever that translates to in rating but is higher than original and never been any problem, when get a few minutes will have a look under bonnet and check rating. Look's Like 95Ah 850A. UK code 019 AGM
Sun Aug 13 2017 6:53am |
Looks like an original battery get it changed and see if you can get a 95 ah one for a bit more power |
Sun Aug 13 2017 6:55am |
Cheers Col & Geoff
Sun Aug 13 2017 7:03am |
Does sound like a new battery would be a good idea.
Sun Aug 13 2017 10:22am |
Thanks for all the comments.
Sun Aug 13 2017 12:27pm |
Well thanks for all the help and advise
Sun Aug 13 2017 6:45pm |
Never ever done that.That sounds very dodgy to me |
Sun Aug 13 2017 6:47pm |
Geoff,
Sun Aug 13 2017 6:56pm |
Do not think they will but cranking amps will always make starting easy Cant actually believe they changed a battery with the engine running t hat could be so dangerous |
Sun Aug 13 2017 7:28pm |
