Home > Maintenance & Modifications > Battery drain
Guyzer73
Oman 2006 Range Rover Sport Supercharged Vesuvius Orange
Battery drain
Hi All,
Hope your weekend is going better than mine... Smile
So as the title says I've got battery drain from a steady 12.5V when engine is off, or 14V+ when running across the terminals tonite being almost dead overnight... Confused
Obviously loads on here about it and I suspect an earth leak simply because after jump starting and a good 1 hour run at 3000rpm and above all seems well, no error messages etc.
One extra titbit bis that the obd port doesn't seem to be powered anymore. Regardless of engine on or off my iid tool doesn't work.
Any ideas where to look first?
Any recommendations appreciated.
Have a great weekend.
Guy 2006 RRS S/C CONSTANTLY under modification...
1994 RRC 4.2l not LSE sadly gone but not forgotten
LR Defender 300Tdi - affectionately know as "The Black Beast"
Post #532624 Sat Aug 12 2017 5:32am
Guyzer73
Brief update, checked voltage this morning and it's 11V across the terminals... 2006 RRS S/C CONSTANTLY under modification...
Post #532626 Sat Aug 12 2017 6:25am
V.
Alternator?
I think these have a big fuse in the big battery cable going to the starter.
Measure voltage across it with engine off and charged battery.
On 2v range. If u get 1 volt ish it's alternator.
Alternitivky remive fuse over nite and see if it remains charged. This is a good idea to save your battery.
This applies where the battery is going flat quick
P.S Typed on my mobile, when still asleep Rolling with laughter
Post #532632 Sat Aug 12 2017 8:00am
Guyzer73
Hi Andy,
Thanks for the tips I'll give them both a try Thumbs Up
Have a good weekend
Post #532633 Sat Aug 12 2017 8:19am
Bodsy
Site Sponsor
Common drain is the rear tailgate handle switch. Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #532679 Sat Aug 12 2017 8:11pm
Guyzer73
Cheers Bodsy,
I'll get that checked out also.
Could you give you opinion on my thoughts:Based on my logic (not the best Very Happy ) I think it could be the battery. Basically, charged it overnight and whilst charging it showed 14V+ across the terminals. This morning the battery showed 12-13V across the terminals when disconnected. PLease note I have a Censored analogue multimeter, nothing flashy.
However, when connected and I allowed the car 'settled down' after running its diagnostics, and whatever, after the battery was connected I tried starting the car and it struggled to start. Normally, I give the key a 'quick' turn to 'ignition' and release and the car starts immediately. This time nada... So I tried again and held key in position and it started eventually.
Took it to the garage to get sorted as have to work...
Just to be sure, what is the correct specs for the battery. The car is a 2006 4.2SC?
I have an OEM LR Varta battery installed and it's rated at 700A/ 80Ah, but, when I use the Varta website they recommend batteries in excess of 830A and 95Ah Could this be the problem? Especially, considering that I do at lot of short journeys with AC etc. running?
The battery is a 80Ah 700A batter with manufacturer code 6G9N-10655-RC as per the pic below:
Thanks for all the help.
Post #532693 Sun Aug 13 2017 6:03am
That's the same rated battery my 5.0L S/C had from new, the petrol one's seem to be lower rated than the diesel spec. ones. I actually replaced mine with a Varta AGM Stop/Start battery I think it was type G14 whatever that translates to in rating but is higher than original and never been any problem, when get a few minutes will have a look under bonnet and check rating. Look's Like 95Ah 850A. UK code 019 AGM
Post #532694 Sun Aug 13 2017 6:53am
geoffsnook
Looks like an original battery get it changed and see if you can get a 95 ah one for a bit more power Thumbs Up
Post #532695 Sun Aug 13 2017 6:55am
Guyzer73
Cheers Col & Geoff Thumbs Up
That was my thought once it's confirmed to be a dead battery...
I'm surprised at the OEM rating (700A/ 80Ah), as whenever I google that I get results for the RR Ewok and not Sport Confused For the Sport I've always found recommendations in line with what you have written/ recommended or sometimes even higher (100Ah, but, I guess that's for the V8 diesel in cold climates Question )
I'll call the garage to make sure they put in a higher rated battery if that's the fault.
Thanks again and have a good Sunday Thumbs Up
Post #532696 Sun Aug 13 2017 7:03am
Does sound like a new battery would be a good idea.
I would expect a 90Ah one really, (but yes I know they have been fiting 80's)
Post #532708 Sun Aug 13 2017 10:22am
Guyzer73
Thanks for all the comments.
The garage has confirmed that the battery is FUBAR'd and that LR here only carries that one battery type... Evil or Very Mad
So will collect the car runn ing and head to a battery shop, can anyone recommend a DELCO battery suitable for the Sport?
Post #532716 Sun Aug 13 2017 12:27pm
Guyzer73
Well thanks for all the help and advise Thumbs Up
Problem now solved. Rather than going with an AC Delco battery ended up with a Bosch S5 013 100Ah 830A, Type 019 battery.
One thing that shocked me was how the guys changed the battery... with the engine running Shocked
I'd initially left it running and when I saw that they were going to start disconnecting the old battery I turned off the ignition. They shook their heads and said "no, no, engine on" Shocked , so I did and they then proceeded to remove the cables from the terminals -ve then +ve I think and the fit the new Bosch battery...
Can't believe that's standard practice, but, I'm sure a knowledgeable person will advise accordingly.
One interesting fact is that Tayna/ Bosch in the UK offer 5 years on the battery in Oman only One...
I'm looking forward to the car starting without problems in the morning.
Have a good evening.
Post #532743 Sun Aug 13 2017 6:45pm
geoffsnook
Never ever done that.That sounds very dodgy to me Whistle
Post #532745 Sun Aug 13 2017 6:47pm
Guyzer73
Geoff,
You're telling me... I was there watching them going Censored Censored Censored expecting one of them to be flying through the air with smoking hair...
Another interesting thing is that on checking the Tayna site they actually recommend an even bigger battery than the Bosch I installed Shocked
Instead of the 019 battery they recommend an 020, so 110Ah and 920A or there about. So why did LR install a 80Ah 700A battery?? I'll sleep on that.
Perhaps a LR rep could explain?
Post #532746 Sun Aug 13 2017 6:56pm
geoffsnook
Do not think they will but cranking amps will always make starting easy Thumbs Up Cant actually believe they changed a battery with the engine running t hat could be so dangerous Thumbs Up
Post #532749 Sun Aug 13 2017 7:28pm
