Home > General > Engine top end strip down |
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1061 |
Dont forget to check the cam chain etc - if it has broken or become jammed that could be another reason each cam feels different - I have heard that the valves crashing into pistons on one side of the engine and the cam coming to a sudden stop can cause the cam chain or its bits to also fail.
Thu Aug 10 2017 12:14pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4793 |
You replace the damaged ones.
Thu Aug 10 2017 12:47pm |
DerrekL Member Since: 23 Jul 2015 Location: West Lothian Posts: 240 |
Cheers... so a replacement head could be the way to go.
Thu Aug 10 2017 2:24pm |
yeah while its in bits, you need to remove the other head for inspection.
Thu Aug 10 2017 7:44pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4335 |
Yes, both heads need removed for inspection
Thu Aug 10 2017 8:04pm |
I did break off a valve in my old subaru - the valve head bounced around putting dents and gouges in the top of the piston and head - being tight I just replaced the valve and put the head back on - car ran fine for at least another 200,000km until I sold it. Is not recommended but something to consider 07MY RRS TDV6 Arctic Frost Aspen Interior |
Fri Aug 11 2017 4:11am |
Thanks for replies....
Fri Aug 11 2017 9:09am |
The rear cam pulley is a
Fri Aug 11 2017 10:51am |
OK not looking too great for me then. I will try to tackle these jobs you listed one at a time DM. Is there any guides on here for these jobs? RRS 2.7 HSE Stornoway Grey
Fri Aug 11 2017 11:23am |
I've taken the head off in situ.
Fri Aug 11 2017 11:54am |
OK cheers Andy, that will be this weekends to-do list RRS 2.7 HSE Stornoway Grey
Fri Aug 11 2017 12:25pm |
slowly getting all the parts off the LH side... however how the does the plastic box (part of the wiring loom I think) come apart that sits directly above the 3rd injector? RRS 2.7 HSE Stornoway Grey
Fri Aug 11 2017 6:53pm |
Hopefully you have the cambelt guide printed out.
Fri Aug 11 2017 7:24pm |
abilover Member Since: 03 Oct 2016 Location: East Yorkshire Posts: 29 |
This is compelling stuff, following this one with great interest. Many thanks to DerrekL for the regular updates. Hope for a satisfactory conclusion |
Fri Aug 11 2017 7:27pm |
