Home > Faults & Fixes > sunroof |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4851 |
Yes you can adjust them, but it is quite possible you may need a new rubber.
Tue Jul 25 2017 9:22am |
Yep thought it may be standard fit how do you adjust them as it does look a bit low |
Tue Jul 25 2017 9:29am |
If you look at the Left and Right side of the sunroof you will see what looks like a convoluted piece of rubber, if you remove those they are only a sort of push fit. Underneath at each end there is a small torx headed screw, I think they maybe something like a 15 can't remember off hand, loosen them and you can then move/adjust the sunroof then just retighten the screws, I think they are torqued to about 6 Nm.
Tue Jul 25 2017 10:04am |
will look later |
Tue Jul 25 2017 10:16am |
Hi just had a look and the adjustment seems to be all the way up but my sunroof appears to be sitting a bit low as none of it is above the roof line it actually appears to be sat below the roof line |
Wed Jul 26 2017 3:47pm |
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2007 |
Crap design. I will never buy a car with a sunroof ever. Visitor from fullfatrr.com
Wed Jul 26 2017 5:03pm |
Yes it proberly is but I am stuck with it but would like it to at least attempt to stop the rain coming in |
Wed Jul 26 2017 5:10pm |
Old Disco and RRClassic owners used to Duct Tape theirs on the outside Visitor from fullfatrr.com
Wed Jul 26 2017 5:22pm |
Really do not want to resort to that but I am sure I won't |
Wed Jul 26 2017 5:27pm |
BJH1959 Member Since: 25 Mar 2017 Location: Paredes de Coura, Portugal Posts: 407 |
After a deluge of rain it started to seep through the front corners of the sunroof. After reading previous entries on this Forum I was able to quickly identify blocked drainage holes. Sorted. And again, thanks. Barrie.
Fri Mar 30 2018 2:22pm |
Cymruambyth Member Since: 27 Feb 2017 Location: North Wales Posts: 1533 |
I too had a small shower last night as I drove off my drive....yet another thing to me off. Steve. |
Fri Mar 30 2018 2:25pm |
Meiang Member Since: 29 Apr 2011 Location: Perth Posts: 389 |
Never had any leaks with my sunroof. The only problem I find is that dust builds up between the rubber and the painted metal opening and scratches the painted surface badly. This is a problem in a dusty environment as I have had a similar problem with previous cars.
Sat Mar 31 2018 11:19am |
stagfinder Member Since: 17 Dec 2015 Location: Peterborough Posts: 22 |
I stuck a new seal on mine about 2 years ago not leaked since |
Sat Aug 04 2018 11:14pm |
