Home > Faults & Fixes > sunroof
geoffsnook
sunroof
I sat in my sport the other day in the rain and the sun roof blind was open and i could see the rain dripping in through the corners so can you adjust the sunroof to fit the opening as i can see a gap or do i need a new rubber or do i have to live with it which i dont want to do as if you park it facing downhill water drips through the light Thumbs Up
Post #531167 Tue Jul 25 2017 8:49am
Yes you can adjust them, but it is quite possible you may need a new rubber.
Please Note: A leaking Range Rover Sunroof is a standard factory fitted option. Rolling with laughter
Post #531168 Tue Jul 25 2017 9:22am
geoffsnook
Yep thought it may be standard fit how do you adjust them as it does look a bit low Thumbs Up
Post #531169 Tue Jul 25 2017 9:29am
If you look at the Left and Right side of the sunroof you will see what looks like a convoluted piece of rubber, if you remove those they are only a sort of push fit. Underneath at each end there is a small torx headed screw, I think they maybe something like a 15 can't remember off hand, loosen them and you can then move/adjust the sunroof then just retighten the screws, I think they are torqued to about 6 Nm.
Don't know if instructions below make sense but it is from L/R workshop manual.
With the roof opening panel closed, check the
alignment of the glass to the roof panel. The glass
should be central in its aperture. Profile of sunroof
to body: front edge, set flush or up to 1.0 mm
(0.040") low; rear edge, set flush or up to 1.0 mm
(0.040") high.
Post #531171 Tue Jul 25 2017 10:04am
geoffsnook
Cool will look later Thumbs Up
Post #531172 Tue Jul 25 2017 10:16am
geoffsnook
Hi just had a look and the adjustment seems to be all the way up but my sunroof appears to be sitting a bit low as none of it is above the roof line it actually appears to be sat below the roof line Thumbs Up
Post #531294 Wed Jul 26 2017 3:47pm
DrRob
Crap design. I will never buy a car with a sunroof ever. Visitor from fullfatrr.com
2011 Vogue SE 4.4 TDV8 Full Fat
GONE - RRS SDV6 HSE MY2012 in Orkney Grey.
1993 200Tdi Tdi Range Rover - a proper Rangie!
1949 Series One 80" in family since 1975! Where it all began.....
Post #531306 Wed Jul 26 2017 5:03pm
geoffsnook
Yes it proberly is but I am stuck with it but would like it to at least attempt to stop the rain coming in Rolling with laughter
Post #531310 Wed Jul 26 2017 5:10pm
DrRob
Old Disco and RRClassic owners used to Duct Tape theirs on the outside Rolling with laughter Visitor from fullfatrr.com
Post #531313 Wed Jul 26 2017 5:22pm
geoffsnook
Really do not want to resort to that but I am sure I won't Thumbs Up
Post #531316 Wed Jul 26 2017 5:27pm
BJH1959
Portugal 2005 Range Rover Sport TDV6 HSE Cairns Blue
Thank you yet again Forum.
After a deluge of rain it started to seep through the front corners of the sunroof. After reading previous entries on this Forum I was able to quickly identify blocked drainage holes. Sorted. And again, thanks. Bow down Barrie.
2005 RRS LHD Cairns Blue 2.7HSE (remapped) 20" wheels.
Post #552685 Fri Mar 30 2018 2:22pm
Cymruambyth
Wales
I too had a small shower last night as I drove off my drive....yet another thing to Censored me off. Steve.
Post #552687 Fri Mar 30 2018 2:25pm
Meiang
Australia 2010 Range Rover Sport TDV8 HSE Santorini Black
Never had any leaks with my sunroof. The only problem I find is that dust builds up between the rubber and the painted metal opening and scratches the painted surface badly. This is a problem in a dusty environment as I have had a similar problem with previous cars.
I rarely ever open the sunroof. I clean the rubber seal and the painted aperture openning once a week to prevent the painted surface from deteriorating.
I use Zymol Seal to keep the sunroof seal from getting hard.
Post #552784 Sat Mar 31 2018 11:19am
stagfinder
England 2006 Range Rover Sport TDV6 HSE Bonatti Grey
Re: sunroof
I stuck a new seal on mine about 2 years ago not leaked since
Post #562667 Sat Aug 04 2018 11:14pm
