Home > Maintenance & Modifications > correct way of jacking up rear of my rrs |
Chock the front wheels. Just put it into off road height and jack at the jacking point at the rear of the chassis rail where the hole is. Then position axle stands under the chassis rail preferably with a wood block to protect the rail. You will find all sorts of nonsense on the forum about putting it in access height, turning on the hazards and opening the rear hatch - none of it is correct.
Wed Jul 12 2017 3:33pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4800 |
personally wouldn't bother to use wood on the RRS.
Wed Jul 12 2017 5:50pm |
Using wood when jacking is more to prevent rust, as you don't damage the paint and expose the metal to the elements. Granted it's hardly going to ruin the car overnight, but it's better to prevent than cure! (You lose nothing by using a lump of wood and dependant on your jack you get a better grip on the chassis, reducing the chance of the jack slipping) |
Wed Jul 12 2017 11:19pm |
you certainly do, with normal cars, but the RRS just has those rails which doesn't show rust on the outside. |
Thu Jul 13 2017 12:12pm |
steve.rrs Member Since: 27 Aug 2014 Location: devon Posts: 90 |
thanks guys, if the weather stays dry tomorrow i'll have a go at jacking it up
Sat Jul 15 2017 9:39pm |
CANROVER Member Since: 03 Oct 2015 Location: Ottawa Posts: 255 |
Jack up the rear frame and place on Jack stands then jack the rear control arm of the side you want to work on. If you're just jacking up one side at a time then chock the opposite side front wheel or you can do both if you are nervous. |
Sun Jul 16 2017 1:57am |
Sun Jul 16 2017 2:27am |
http://www.ebay.co.uk/itm/LANDROVER-RANGE-...SwUuFWyNQJ
Sun Jul 16 2017 10:27am |
