Home > Other Site Sponsors > Bodsy's Megaflush service now available!
Bodsy
Site Sponsor
So finally, after many many customers had been asking me if I did it, I can now say that I do!
I've just received Fortron's newest version2 of their Automatic Transmission Flush Machine. This is in addition to all of the other services I offer.
So if your auto gearbox is slow at changing gear, fluctuating revs, slight juddering or hunting between gears then your gearbox may well benefit from an ATF megaflush.
Discovery 3's, Discovery 4's and Range Rover Sports with the ZF-6HP automatic gearbox would normally expect a smooth gear change. However, according to LR, these gearboxes are supposed to be sealed for life so no service schedule includes changing the gearbox fluid. Evil or Very Mad
ZF, the manufacturers of the gearbox, however, recommend that the gearbox fluid is changed around 60,000 miles. This is where a megaflush comes in!
As with any hardworking oil, the gearbox fluid in these gearboxes can get hot and generally worn out. Common signs are torque converter judder, slow and erratic gear changes and what feels like clutch slip as the engine revs but the speed does not increase. This is most common around 3rd gear going uphill or towing.
It is pretty common for the gearboxes to start to show problems from 70/80,000 miles. In most cases, an ATF flush will eliminate these problems with the new fluid. Many owners are choosing to have this ATF fluid service done at lower mileages as a preventative measure rather than wait until they start to get problems.
It's certainly far cheaper to have a transmission flush than it is to have to replace the torque converter! Not to mention, better for the gearbox and for keeping your fuel economy up!
My own Discovery covered 231,000 miles before I changed the torque converter. Even then, it was preventative rather than actually required. I put this down to regular transmission oil changes.
*Removes over 99% of old, worn out fluid
*Replaces exactly the same volume of new fluid (although I always double check the level is correct afterward)
*The correct ZF-6HP fluid is used
*Eliminates common gearbox problems
*Preventative measure for maintaining a heathy torque converter and gearbox Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #528707 Wed Jun 21 2017 8:17pm
Buckster
Good stuff mate, im sure there will be many wanting this here and on Disco forum Thumbs Up 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
2013 SDV6 HSE Black Edition- Orkney Grey with Ebony & Ivory. LR Facelift RAI, Genuine G4 Expedition Rack, 4x Warn SBD-160 Spotlights, Warn 9.5XPS Winch, Mantec Underbody Protection and Sump Guard, Full Easy Lift Suspension Module, LR Light Guards, 19"s on Goodyear Duratracs, ARB fridge, TuffTrek awning 😎
Post #528832 Fri Jun 23 2017 1:09pm
DrRob
Will it do 8 speeders Bodsy? Visitor from fullfatrr.com
2011 Vogue SE 4.4 TDV8 Full Fat
GONE - RRS SDV6 HSE MY2012 in Orkney Grey.
1993 200Tdi Tdi Range Rover - a proper Rangie!
1949 Series One 80" in family since 1975! Where it all began.....
Post #529458 Sun Jul 02 2017 7:10pm
Johnski
That was also my question too. Thumbs Up John
Post #529462 Sun Jul 02 2017 7:21pm
Bodsy
Site Sponsor
The machine will flush everything Laughing , as long as it can connect!
I'm just getting pipework sorted as you're probably aware the 8 speed has a thermostat so can't be done in the same way as the 6 speed.
As soon as I can do the 8 speed, I'll be sure to shout it out!
Hopefully just after the summer holidays should be sorted. Thumbs Up Bodsys Brake Bible
See it HERE
Post #529471 Sun Jul 02 2017 8:39pm
DrRob
Thumbs Up Thumbs Up Visitor from fullfatrr.com
Post #529474 Sun Jul 02 2017 8:53pm
Johnski
Thumbs Up Thanks for reply, will need mine doing later part of year/next year. John
Post #529475 Sun Jul 02 2017 9:06pm
ShooterNeil
England 2007 Range Rover Sport TDV8 HSE Java Black
Price please mines a V8 is it the same 07 HSE TDV8 with lots of toys EGR removed BAS remap
Post #529510 Mon Jul 03 2017 3:57pm
Bodsy
Site Sponsor
Tdv8 is ok too for that year. I'll drop you a message Thumbs Up Bodsys Brake Bible
See it HERE
Post #529516 Mon Jul 03 2017 7:44pm
Roscosc
2010 Range Rover Sport TDV8 Autobiography Alaska White
Gearbox flush
Hi bodsy could you give me price on tdv8 flush in West Midlands cheers
Post #529525 Mon Jul 03 2017 10:02pm
Bodsy
Site Sponsor
What year? Thumbs Up Bodsys Brake Bible
See it HERE
Post #529528 Tue Jul 04 2017 6:03am
Bigbore
England 2012 Range Rover Sport SDV6 HSE Orkney Grey
Re: Gearbox flush
Bodsy
Roscosc profile says 2005 Thumbs Up RRS SDV6 HSE Orkney Grey,Premium Ebony Black leather,MY12 Autobiography Exterior Design Pack,22"Diamond Turned Rotor Alloys,interior LED's/Number plate,boot LED's x 2,rear entertainment,HD Dash cam,ALIVE Remap,Bumper DRL's
Post #529529 Tue Jul 04 2017 7:03am
Roscosc
Hi mate sorry it's a 2010 tdv8 just gone on to 100000
Post #529538 Tue Jul 04 2017 9:01am
Bodsy
Site Sponsor
Got a little confusing with tdv8 described, but V8 s/c in profile.
Lol, but I'll drop you a message. Thumbs Up Bodsys Brake Bible
See it HERE
Post #529879 Sun Jul 09 2017 12:23pm
Roscosc
Hi mate won't let me private msg back if you could send a number I'll call you Cheers,,forgot to change profile
Post #529995 Mon Jul 10 2017 5:33pm
