Home > Technical > URGENT HELP NEEDED mis fire |
Does it have lpg |
Sat Jul 08 2017 9:05pm |
Revaj110u Member Since: 08 Jul 2017 Location: Wales Posts: 13 |
Yes it does mate runs the same on lpg as it does on petrol
Sat Jul 08 2017 9:31pm |
Does it have a lube system and would you know how many miles it has done on lpg as these engines are know to suffer with valve seat recession but there are other options to try first |
Sat Jul 08 2017 9:41pm |
I know it does not have the valve saver . I belive it's done around 40k on it since fitted I've had it about 8 months not and never had a fault with
Sat Jul 08 2017 10:00pm |
GodivaNige Member Since: 14 May 2016 Location: Warwickshire Posts: 420 |
Compression test of each cylinder? |
Sat Jul 08 2017 10:05pm |
Yeah check compression as you have tried a few things or you could try moving the coil packs around as see if that makes a difference how many miles on her and what's the service history like |
Sat Jul 08 2017 10:29pm |
Will the compression show duff valves ? If so that my first option in the morning.
Sat Jul 08 2017 10:53pm |
Do the compression test at least it will rule the valve seats out |
Sun Jul 09 2017 6:43am |
Will do that first thing . Will let you know how it goes later on
Sun Jul 09 2017 8:41am |
Just done the compression test mate all showing between 160 and 175 psi
Sun Jul 09 2017 11:53am |
I'm not an engineer or an LPG fitter and have only experience of diesel RRS but from reading posts on here about LPG there seems to be a variety of operating systems for LPG installations - is yours the sort that starts the car on petrol and then when warmed through automatically changes over LPG? If the misfire only occurs at that stage I would suspect either a leak in the LPG system or the change-over valve/s have a problem, or the control unit has failed possibly. Do you get the problem when only running on Petrol? 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Sun Jul 09 2017 1:23pm |
Well the car getting better slowly haha
Sun Jul 09 2017 3:55pm |
Can you get hold of a smoke tester and see if you have any air leaks or use a brake cleaner to spray around the intake area to see if there are leaks as you have no codes on it should not be rallt as you would then get some p codes as to be too lean or it may be a blocked fuel filter |
Mon Jul 10 2017 8:07am |
Tim as far as i know they all start on petrol then change over to gas |
Mon Jul 10 2017 8:08am |
