Home > In Car Electronics > Device error |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1532 |
Have you tried deleting it from the RRS and deleting the RRS link from the phone and then starting again? Robin
Fri Jul 07 2017 10:25pm |
sundeepbakshi Member Since: 17 Apr 2014 Location: berkshire Posts: 13 |
I haven't but it sounds like a great idea?
Fri Jul 07 2017 11:12pm |
Well I know how to delete it off phone but maybe you can explain what you mean just so I have the full picture. |
Fri Jul 07 2017 11:13pm |
Hmm - I think I might have been a little optimistic thinking you can easily delete it from the RRS. However what I'd do is:
Sat Jul 08 2017 7:55am |
Thanks for the detail. When I got up this morning I went out to the the car. Just got in and seen your next message. What I did was forget Bluetooth device switched if etc but still nothing. I changed the name of my iPhone and the rrs console still says device error with the old name.
Sat Jul 08 2017 8:09am |
Yes, my procedure is for resetting the RRS system on your phone and I agree with you that it isn't obvious how you can remove phones from the RRS system. It does say you can have up to 8 phones but doesn't say what happens if you try to connect a 9th. Logic says if you tried to connect a 9th then the first one connected would be lost but that doesn't seem to be the case for you.
Sat Jul 08 2017 8:46am |
thank you for your time and help...i have been thinking about the hard reset, did it before when funnily enough i had audio issues.
Sat Jul 08 2017 9:15am |
It wasn't a lot of help really -but do publish your resolution when you get there. Best of luck Robin
Sat Jul 08 2017 11:01am |
scousefly Member Since: 25 Jan 2015 Location: sheffield Posts: 248 |
I found that the issue cleared when I reloaded the apple tunes app which I had deleted a couple of days before. Don't understand why it needed apple tunes on the phone as I don't use it I always use Spotify but it now works |
Sat Dec 01 2018 10:01am |
There's nowt so queer as .... electrics Robin
Sat Dec 01 2018 10:28am |
