Home > General (L494) > Coolant Level Low |
richamartin Member Since: 16 Dec 2012 Location: Cotswolds Posts: 251 |
I had the same on mine, when it went off I drove it to LR dealer and they topped it up FOC.
Tue Feb 16 2016 9:09am |
Autobiography Member Since: 19 Jun 2012 Location: Londres Posts: 336 |
Got a leak apparently. Was 5cm below the minimum but warning first time today! |
Tue Feb 16 2016 6:30pm |
Dave777 Member Since: 15 Feb 2015 Location: Sussex Posts: 485 |
My friend bought a brand new Evoque a few months back. 2 days later it left all its coolant on their drive and was taken away by LR assist!
Tue Feb 16 2016 10:14pm |
Rose its head again this morning. Said it needs to go to dealer urgently |
Wed Mar 16 2016 1:10pm |
Davemeldrum Member Since: 31 Dec 2016 Location: Dundee Posts: 1 |
Hello,
Sat Dec 31 2016 6:57pm |
Hodog16 Member Since: 10 May 2015 Location: North Carolina Posts: 64 |
Old thread but just had this alarm come up today. It went away after a few seconds and as I had a short errand to run decided to see how the car did. No problems and temperature remained okay. Starting up on way home did not get alarm.
Sun Jul 02 2017 10:18pm |
Black Bess Member Since: 09 Sep 2013 Location: Lincolnshire Posts: 245 |
Have you checked the level of coolant in the header tank? |
Mon Jul 03 2017 9:04am |
I did try to check and it's hard for me to see. It looks like the tank is L shaped or so. There's pink fluid on the left but the markers are at the bottom on the right and it looks like there is fluid there but it's hard to see. At any rate going to take it to the dealer on a Wednesday. 2016 SCV8 Dynamic - Firenze Red/Pimento |
Mon Jul 03 2017 1:34pm |
Went to dealer today. They said the level was slightly low but did a pressurized test and there were no leaks. Topped off the fluid.
Wed Jul 05 2017 11:50pm |
Netsters Member Since: 07 Nov 2011 Location: London Posts: 175 |
Same here, had it intermittently over the last couple of weeks. Couldn't face going to the dealer and getting booked in for what was likely to take a lot less time to fixed than waiting to be seen. Called Land Rover assist, who sent someone out. Exactly that, coolant was on the borderline so was only triggering. Topped up and did pressure test. All was OK. Range Rover Sport SVR - Santorini Black
Sat Jul 15 2017 3:03pm |
donny dog Member Since: 23 Nov 2016 Location: yorkshire Posts: 772 |
Water does expand a small amount with temperature, so this might cause it to rise and fall the critical amount to operate the level transducer. Probably better to top up over the line to avoid this happening. |
Sat Jul 15 2017 4:05pm |
