Home > In Car Electronics > Tilting door mirrors on reverse and park camera yellow lines |
If fitted then the reverse dip you set up yourself by engaging reverse then adjusting the mirrors to see what you want when you reverse. The yellow lines on the reversing cam are pre-programmed, there are two sets........ solid ones that bend with the steering input and a 2nd pecked set that are the mirror tips. Additionally when you reverse or drive up to an object then you will get amber warning blocks then red ones as you approach the object. This lot is all connected to the parking sensors.also when the yellow set at the back turn red you are too close to the object to open the tailgate without hitting something. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Fri Jun 30 2017 7:14pm |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 749 |
Appreciate your patience, I currently have a Honda Civic which doesn't even posses a CAN bus, and obviously want to make sure everything works ok when viewing cars. SWMBO laughs each time I take my 4 page check-list out. I get my own back by sitting her in the drivers seat to press all the switches . |
Fri Jun 30 2017 7:22pm |
And I hear Honda's never breakdownthey just expire from old age......... we have 2 generations of Civics - one of the Rover built Civics that is now 20 years old and is my Mum's car that does less than 1500 miles a year but sails through MOT's, my sister has a later version with the same boring reliability and my Dad has a 2010 Jazz with the most awful CVT autobox but otherwise is another boring car. But then I have 2 boringly reliable Land Rovers - a 21 year old Defender and a 2.5 year old RRS. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Fri Jun 30 2017 7:32pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4797 |
Reverse dip can be turned on and off, but obviously the car needs the seat memory pack. |
Fri Jun 30 2017 8:21pm |
M3DPO Member Since: 30 Apr 2013 Location: Notts Posts: 32 |
Which is fitted on all HSE's most SE's. |
Fri Jun 30 2017 10:42pm |
It's been HSE's that I have viewed thanks.
Sat Jul 01 2017 11:23am |
