Home > General > HDC systerm fault ? |
Richard039 Member Since: 17 Nov 2016 Location: Surrey Posts: 29 |
I've had the same thing happen to mine. After reading some other forums the fault seems to be the brake light switch. Strange but apparently true. The minute I get a chance to do mine I will let you know what happens |
Fri May 26 2017 6:18pm |
Rob199026 Member Since: 02 Jan 2017 Location: Essex Posts: 39 |
Hi mate
Fri May 26 2017 7:01pm |
I seem to remember something about that in the other forum. They said before you swap the switch check that both bulbs are okay. You just reminded me, thanks |
Fri May 26 2017 9:10pm |
Topsy Member Since: 06 Jan 2017 Location: Swansea Posts: 48 |
Hi
Fri May 26 2017 9:32pm |
I finally bought a brake light switch, which seems to have cured the problem |
Fri Aug 25 2017 9:46pm |
