Home > Maintenance & Modifications > Tdv8 Battery replacement |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4790 |
Maybe a ctek 5 charger would be better if you have a handy power supply by car |
Tue May 23 2017 9:29pm |
Lonerangerv8 Member Since: 16 Sep 2015 Location: Cheshire Posts: 83 |
It is a ctek 5 charger that I use. |
Tue May 23 2017 9:32pm |
d-9 Member Since: 10 Jan 2017 Location: Herefordshire Posts: 299 |
I think mine is a varta agm battery, was about £175 and has solved a whole bunch of random faults I was getting. |
Tue May 23 2017 11:05pm |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8844 |
Be worth checking the alternator. Do you do mostly short runs? With regular hour-plus runs, the battery should be kept in decent charge unless the alternator is tired. On short runs it might just be struggling to get meaningful charge even with a good alternator. Short runs and tired alternator would be a recipe for trouble.
Tue May 23 2017 11:22pm |
Wed May 24 2017 11:42am |
Boothy Member Since: 30 Mar 2017 Location: Herts Posts: 59 |
I got a bosch battery from costco for circa £130 |
Thu May 25 2017 12:14pm |
