Home > General (L494) > few annoying issues |
matsoutback Member Since: 13 Jul 2016 Location: Queensland Posts: 152 |
I would be getting the vibration looked into for sure as a warranty issue. As for the memory seats, don't have them so can't comment except with the Touareg, when exiting the vehicle, you would sometimes drag your bum over the switches, subsequently making slight adjustments to the seat position for the next time. There were a few complaints about that if I recall correctly. 2017 MY17 SDV6 SE |
Tue May 09 2017 12:04am |
Autobiography Member Since: 19 Jun 2012 Location: Londres Posts: 330 |
The seat memory is a known issue but LR cannot fix it... |
Tue May 09 2017 6:33am |
IRBails Member Since: 22 Nov 2013 Location: Wollongong Posts: 863 |
Well just got another issue car at dealer limp home mode!!! Did find the fuel filter though. M16 SVD8 ,4.4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW. |
Tue May 09 2017 8:24am |
donny dog Member Since: 23 Nov 2016 Location: yorkshire Posts: 772 |
I have a MY17, and don't have either of these problems (and I also have my seat at the top of its height adjustment). |
Tue May 09 2017 9:34am |
Well the Limp home mode with no explanation is a worry. First time with a car just 18 months old needs to be towed. Hope this is not a pre curser to Range Rover ownership. will get the low down tomorrow on what the issue is the workshop was full of cars so perhaps I will be without the car for awhile. Here's hoping it is just an electrical fault ? M16 SVD8 ,4.4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW. |
Tue May 09 2017 11:54am |
I'm sorry to hear that Bails... Interested to see what the outcome is today. I agree with you, not a good intro to RR ownership.
Tue May 09 2017 9:36pm |
DrFox1969 Member Since: 02 Feb 2016 Location: Adelaide Posts: 190 |
Hope its gets sorted out soon IRBails. Nothing more frustrating than getting towed.
Wed May 10 2017 5:19am |
OK car fixed but still at dealers. I must say I really like the tech at Southern classic, a real trade qualified guy that gets on the tools. Went through the issues with me which turned out to be boost controller fault earth to ground earth to positive something like this. Got a PCM upgrade that should take care of the issue. Also fixing my front park sensors which required another part which should be in tomorrow. They will look into the brakes and seat issue as well but I am in no hurry for the seat.
Wed May 10 2017 7:05am |
Good outcome Bails, I always expected I'd get to know the service guys more than with my Landcruiser...
Wed May 10 2017 8:17am |
Well picked my car up and fault still there. Some times goes to limp other just the engine light stays on. Quite annoying . They were also supposed to fix the front park sensors but these are still not working. Tried to get a copy of the fault codes but could not as the tech with the info wasn't there. Seems the fault is turbo related is a real pain in the ar$e, Good start for a new car with 24.000 miles. Hope this isn't a sign of things to come. M16 SVD8 ,4.4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW. |
Fri May 12 2017 8:29am |
Not fun mate... I hope you get a decent diagnosis and remedy shortly. I agree, not a good start... 2017 MY17 SDV6 SE |
Fri May 12 2017 11:02pm |
Hate these sort of issues. The tech refer to the codes and these can really mean anything. They have cleaned terminals, which plsses me off as a 4WD should not be subject to corrosion. I am now researching code readers , seems there is a vast array of reader that will reset codes which is my main concern as I don't want to be stuck purely for a reset . I wish I had the actual codes then I could do some good research. M16 SVD8 ,4.4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW. |
Fri May 12 2017 11:51pm |
Found a cable to use with this software and guess what on the trial version it worked. The cable I had kicking around so this might be an easy first solution for me.
Sat May 13 2017 2:24am |
Which cable did you have kicking around? 2017 MY17 SDV6 SE |
Sat May 13 2017 2:34am |
