Home > Faults & Fixes > Clicking noise and easing in roundabouts: |
innox Member Since: 26 Sep 2015 Location: Lucca Posts: 1 |
I was surfing the forum since i am experiencing the same noise on my MY2010 3.0 RRS
Thu Apr 27 2017 12:50pm |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1532 |
Can you eliminate wheel bearings? Robin
Thu Apr 27 2017 1:08pm |
H18GYD Member Since: 08 Jan 2017 Location: Warlingham, Surrey Posts: 8 |
Hi ya, thank you INBOX AND EATERS.... I have spent another grand and guess what... it's still there! I have eliminated the wheel bearing EATERS... but thank you. |
Thu Apr 27 2017 4:18pm |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8847 |
A ticking when turning is most likely a CV joint, to be honest.
Thu Apr 27 2017 7:33pm |
One other thought - what size wheels and tyres are fitted? One wonders if it might just be something rubbing when on/near full lock. 2012 SDV6 - it's missing a couple of cylinders
Thu Apr 27 2017 7:34pm |
Many thanks RRSTDV8, I am not a mechanic so I have to rely on others to do my work for me and of course this cost "lots-a-lolly" so the grand was parts labour for wheel bearing and drive shaft, if I'd have gone to my local Range Rover dealer he was quoting over £1600 plus vat! So it was quite cheap. I was informed that it is not CV joint as both sides were tested. As for the wheels they are genuine Ranger Rover wheels with Michelin tyres... I could drive it up to Northamptoshire and see a decent bloke up there and see if he knows how to find my issue!
Fri Apr 28 2017 12:31am |
I see you're in Surrey. If you ever travel eastwards into Sussex, then I would recommend that you consider popping in to see the guys who sorted out my issues. Groombridges in Heathfield are LR only repair garage who have been going for many years and have an in depth knowledge of these cars. Of course there's no guarantee that they can solve your issue, but if its not out of your way it would be worth a visit. Robin
Fri Apr 28 2017 7:07am |
Well changing the driveshaft (half shaft) is one way of checking the CV joint isn't the issue I suppose. The CV joint is part of the shaft assembly... 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Fri Apr 28 2017 5:00pm |
Many thanmks eaters. I will look in to them as it's only 50 minutes from me. Thank you very much again. |
Fri Apr 28 2017 8:46pm |
Good. Might be worth giving them a ring first although I didn't when I first went there. I just turned up and they went straight out with me on a test drive and diagnosed my problem within 5 minutes.
Sat Apr 29 2017 8:22am |
thank you again... I look forward to letting you know my results. |
Sat Apr 29 2017 11:48pm |
