Home > Technical > Help required! TDV8 A/C condenser removal |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4339 |
Your not far away
Sat Jul 09 2016 4:10pm |
ragpicker Member Since: 21 Mar 2016 Location: Teesside Posts: 47 |
Sat Jul 09 2016 4:15pm |
Never actually done one on a TDV8, but done them on the 4.2 which is very similar.
Sat Jul 09 2016 4:39pm |
Rasher 007 Member Since: 12 Jan 2016 Location: Ashford kent Posts: 13 |
Hi fella, changed mine yesterday so know what you are talking about!!! I undid top pipes and top 2 bolts from the intercooler and also the 2 bolts thru front air duct from bottom of intercooler. This allowed more movement. As you look at vehicle from front, the right hand air duct screw that you talk about can be undone with an air ratchet and 8 MM. socket but the left one is basically impossible. Undo the right one and with intercooler movement you can wiggle the right side free but the tabs on the bottom that the bottom bolts go thru on condenser ( 4 bolts in all)! Are what's hooking up on plastic cowling. Look at new condenser and you will see the 4 tabs. When you start wiggling condenser about, you will see. I gently used a pry bar to ease plastic on left hand side. Any consolation, new one goes in easier!!!!! This is all assuming you undid all 4 bolts that hold condenser to intercooler. Also, whilst intercooler is loose clear leaves and litter from between it and main radiator. Hope this helps If a hammer won't fix it.... It's electrical!! |
Sat Jul 09 2016 8:05pm |
Cheers Rasher!!
Sat Jul 09 2016 8:12pm |
No need to wiggle to see front 4 bolts but they are the same as top 2 and a little hidden behind rubber flaps looking thru air duct at front it would help if you could see a new condenser so you have an idea where you're looking
Sat Jul 09 2016 8:22pm |
Where did you get the condenser and how much?
Sat Jul 09 2016 9:22pm |
Hello again .i do quite a bit on cars and local motor factors got it for me (sc spares in Ashford Kent and strood) but they got it from auto air in Gloucester . Only £118 but four bolt holes weren't big enough to take original anti vibration grommets not a problem as I made some rubber washers but I seriously recommend you buy 2 new o rings from land rover as you don't wanna risk them leaking!! £9 for the pair!!!!! Yeah! I bloody know 9 quid! I'm gonna try do a link but newbee as you know so il give you all photos and try to answer any questions . I looked at mine again and you can't see bottom 2 bolts until bumper is off but they are there!! As I say a bit hidden under rubber flaps . Hope all the pictures help cos you guys on here have helped a lot of people including myself. Job took about four hours with photos, visitors fags and coffee but whose counting? Recharged by a mate for £30 now perfect
Sat Jul 09 2016 10:06pm |
So i thought I'd finish this story off -
Wed Jul 20 2016 9:31am |
Hi ragpicker, just read your final post and pleased to have helped.
Thu Jul 21 2016 4:58pm |
Hello mate!
Thu Jul 21 2016 5:04pm |
