Home > Maintenance & Modifications > Removable tow electrics |
Brutus Member Since: 10 Nov 2015 Location: Cambridgeshire Posts: 67 |
This might help
Fri Jun 24 2016 10:19am |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4790 |
You mean the electric's are unfitted ?
Fri Jun 24 2016 11:29am |
I did mine myself. Quite simple (although I did have the use of a ramp). I didn't need any software update. |
Fri Jun 24 2016 12:08pm |
Gilly1 Member Since: 29 May 2015 Location: Somerset Posts: 203 |
Yes wiring un fitted.
Fri Jun 24 2016 1:22pm |
I seem to have 1 extra wire on my wiring loom, I've circled the wire in red (actual loom) and also circled diagram loom were extra wire is located. Any ideas what/were its for.
Sat Jun 25 2016 2:15pm |
Is it a blue/white spade connection ?
Sat Jun 25 2016 3:01pm |
It's blue/yellow spade end, yes slightly baffled, Everything the same as on diagram instructions thet Brutus provided but just got the extra blue/yellow. May be why the wiring kit was still in the box and not fitted. |
Sat Jun 25 2016 6:11pm |
Is it a 13 pin kit? Single 7 pin or twin ?
Sat Jun 25 2016 6:28pm |
BINGO. I found the instructions, It's optional reverse. So if I want to use it there should be a spade end somewere to connect it too. (Maybe, hopefully, ha. )
Sat Jun 25 2016 7:28pm |
