Home > In Car Electronics > Locking the car
Radek
United Kingdom 2011 Range Rover Sport 3.0 TDV6 SE Santorini Black
Locking the car
I'm having problems locking my RR/S, the key fob has had new batteries but for some reason doesn't lock the car or retract the mirrors, it just sets the alarm. The problem started out as an intermittent fault but now happens every time. When I press the unlock button it seems to operate normally.
Any thoughts out there ?
Post #460578 Mon Apr 27 2015 12:08pm
zaphod
Does it do the same thing with your spare fob?
Post #460580 Mon Apr 27 2015 12:18pm
Radek
Yes it does, my first thought was that the fob batteries needed replacing, but I've done that with no success ?
Post #460594 Mon Apr 27 2015 3:20pm
rrsrad
When you lock the vehicle do you get a double beep? Also do any of the doors lock or is it just one that doesnt (usually drivers door)?
Post #460596 Mon Apr 27 2015 3:58pm
Radek
The car has never done a double beep, it always sets silently, the door lock solenoids can be heard closing once and the mirrors fold inwards. At the present time the solenoids can be heard clicking more than once but none of the doors actually seem to lock, the mirrors do not fold in but the alarm does set and if you open a door the alarm goes off. Occasionally however it does seem to work correctly !
Post #460644 Tue Apr 28 2015 9:50am
rrsrad
I had a similar problem on my 2010 sport last month. When pressing the lock you could hear the solenoids and the power mirrors didnt fold in, however all the doors did lock apart from the drivers door, which when opened started the alarm. Turned out to be a sensor in the latch so had to replace the complete latch which was £330 for a latch, labour and diagnostics. With yours however sounds like a plug in job to check for a ground to earth fault or similar, the indy i took mine to have seen lots with various locking problems apparently
Post #460698 Tue Apr 28 2015 6:21pm
Radek
That sounds about right, I was talking it over with a friend last night and came up with the thought that even when it is working correctly the car will not lock if there is a door partly open, so maybe one of the sensors is starting to fail, then the car will not lock as the CPU believes the doors are not all fully closed. Your comment pretty much confirms this. Thanks for the input ! Very Happy
Post #460735 Wed Apr 29 2015 9:53am
Radek
RR/S locking the car - final result
Sorry for the delay in posting this, but I did take my car to my local Land Rover Independent repair garage, Holgate in Orrell. It was a fault within the latch, this was confirmed by the diagnostics. Andy says he has done a few recently and can get it done in an hour now. New LR latch, diagnostics, labour and VAT = £170.
All works as good as new !
Post #463756 Thu Jun 04 2015 12:20pm
itsmeagain
Just had the same thing with my RRS, both doors on the drivers side wasnt locking.
Changed both locks now all sorted Current 2010 Range Rover Sport HSE with the usual toys: timed climate, Rosen headrest screens, tow bar with twin electrics, Blackvue HD cam
2008 Seat Leon K1
2012 Audi A1 2.0litre Black Edition TDI
2004 Audi A4 convertible
2004 Audi A2 TDI
Post #463780 Thu Jun 04 2015 5:05pm
Ozziev1980
Sorted
Post #493326 Tue Apr 12 2016 8:57am
fdhadi
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Stornoway Grey
I also have a locking problem. When we use our main fob all works well. When we use the spare or 2nd key fob all works well but after about 10mins the alarm sounds.
Any ideas?
Frank
Post #493449 Wed Apr 13 2016 9:34pm
Johnski
Maybe not relevant here, but there was an update article from LR that if changing batteries, they must be brand new from unopened stock, and not use one from a working handset.
I'm sure someone with much more knowledge will assist with other query soon. John
Post #493452 Wed Apr 13 2016 10:10pm
