Home > In Car Electronics > Locking the car |
zaphod Member Since: 16 Jan 2015 Location: Liverpool Posts: 282 |
Does it do the same thing with your spare fob? |
Mon Apr 27 2015 12:18pm |
Radek Member Since: 27 Apr 2015 Location: Manchester Posts: 5 |
Yes it does, my first thought was that the fob batteries needed replacing, but I've done that with no success ? |
Mon Apr 27 2015 3:20pm |
rrsrad Member Since: 05 Feb 2015 Location: Cheshire Posts: 36 |
When you lock the vehicle do you get a double beep? Also do any of the doors lock or is it just one that doesnt (usually drivers door)? |
Mon Apr 27 2015 3:58pm |
The car has never done a double beep, it always sets silently, the door lock solenoids can be heard closing once and the mirrors fold inwards. At the present time the solenoids can be heard clicking more than once but none of the doors actually seem to lock, the mirrors do not fold in but the alarm does set and if you open a door the alarm goes off. Occasionally however it does seem to work correctly ! |
Tue Apr 28 2015 9:50am |
I had a similar problem on my 2010 sport last month. When pressing the lock you could hear the solenoids and the power mirrors didnt fold in, however all the doors did lock apart from the drivers door, which when opened started the alarm. Turned out to be a sensor in the latch so had to replace the complete latch which was £330 for a latch, labour and diagnostics. With yours however sounds like a plug in job to check for a ground to earth fault or similar, the indy i took mine to have seen lots with various locking problems apparently |
Tue Apr 28 2015 6:21pm |
That sounds about right, I was talking it over with a friend last night and came up with the thought that even when it is working correctly the car will not lock if there is a door partly open, so maybe one of the sensors is starting to fail, then the car will not lock as the CPU believes the doors are not all fully closed. Your comment pretty much confirms this. Thanks for the input ! |
Wed Apr 29 2015 9:53am |
Sorry for the delay in posting this, but I did take my car to my local Land Rover Independent repair garage, Holgate in Orrell. It was a fault within the latch, this was confirmed by the diagnostics. Andy says he has done a few recently and can get it done in an hour now. New LR latch, diagnostics, labour and VAT = £170.
Thu Jun 04 2015 12:20pm |
itsmeagain Member Since: 01 Nov 2012 Location: Birmingham Posts: 222 |
Just had the same thing with my RRS, both doors on the drivers side wasnt locking.
Thu Jun 04 2015 5:05pm |
Ozziev1980 Member Since: 12 Feb 2014 Location: London Posts: 15 |
Sorted |
Tue Apr 12 2016 8:57am |
fdhadi Member Since: 17 Feb 2015 Location: Wigan Posts: 180 |
I also have a locking problem. When we use our main fob all works well. When we use the spare or 2nd key fob all works well but after about 10mins the alarm sounds.
Wed Apr 13 2016 9:34pm |
Maybe not relevant here, but there was an update article from LR that if changing batteries, they must be brand new from unopened stock, and not use one from a working handset.
Wed Apr 13 2016 10:10pm |
