Home > Technical > Flashers too fast right side, RRS 2.7 2006 |
Do you have LEDs fitted? Is it the external actual flasher that is too fast or just the flasher on the dashboard? Bodsys Brake Bible
Sun Feb 07 2016 8:39pm |
41664166@online.no Member Since: 01 May 2015 Location: Moss Posts: 127 |
Have Led mounted both front and rear .
Mon Feb 08 2016 3:14am |
Where is the relay located ?
Tue Feb 09 2016 5:42am |
npinks Site Moderator Member Since: 27 Nov 2007 Location: Watching Posts: 6716 |
if its LED, do you have the Canbus style Led's? LED draw so little current that a car can think the bulb is not working, hence the rapid flashing |
Tue Feb 09 2016 11:34am |
How too fix that
Tue Feb 09 2016 11:37am |
I would assume you need to buy canbus style LED's or place a resistor inline
Tue Feb 09 2016 11:49am |
What about a flasher relay for LED lamps ??? |
Tue Feb 09 2016 11:55am |
Lost for Words Member Since: 15 Jan 2015 Location: Warminster, Wiltshire Posts: 1477 |
In common with most of the lights, the indicators are controlled by in-built FETs in the CJB (passenger fusebox). You need not just CANBUS LEDs but proper resitors fitted to get a reliable result so if you don't have these then that's your issue. Visiting from DISCO3.CO.UK
Tue Feb 09 2016 6:46pm |
Where too buy and where too mount them |
Wed Feb 10 2016 3:10am |
50 Ohm ones are suggested to keep the amount of heat generated down - bear this, and water ingress, in mind in terms of location; can't be more specific not having a RRS I'm afraid. You should be able to source them from a typical electrical supplier. Visiting from DISCO3.CO.UK
Wed Feb 10 2016 10:03am |
I have the LEDs fitted in the rear on my RRS 2006
Wed Sep 14 2016 6:35pm |
Believe it or not, the legal flashes for indicators is between 90-120 flashes per minute.
Wed Sep 14 2016 6:59pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4849 |
http://www.powerfuluk.com/range-rover-spor...r-kit.html
Wed Sep 14 2016 7:51pm |
Strange I thought the still did, I didn't think they fitted indicators these days either as you never see them working. Cheers Col |
Wed Sep 14 2016 7:54pm |
