Home > General > Engine System Fault - Suspected fuel pressure issue SOLVED |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4339 |
First of all, do you know what brand of fuel filter was used? Some aftermarket ones are known to cause issues (assuming it was replaced at the service)
Mon Dec 28 2015 8:33pm |
Gav40 Member Since: 12 Jul 2012 Location: Kent Posts: 30 |
Hi, double check that the fuel filter pipes at the filter end are on the correct way round as the White one and the smaller blue ones can be reversed and this will cause the fuel return pipes to expand or blow off under load. May not be your issue but worth a check. |
Mon Dec 28 2015 10:38pm |
Rangie78 Member Since: 28 Dec 2015 Location: Cumbria Posts: 5 |
Thanks for the replies, really helpful.
Thu Dec 31 2015 5:43pm |
Well Gav/Mike, you were both correct!
Fri Jan 08 2016 8:34pm |
Drinky Member Since: 02 Jan 2016 Location: Berkshire Posts: 17 |
Fair play to the garage. |
Fri Jan 08 2016 9:41pm |
