Home > Technical > bluetooth |
sterling01 Member Since: 19 Apr 2015 Location: Kilmarnock Posts: 133 |
You need an updated Bluetooth module. Speak to Wiggs [img]http://www.rrsport.co.uk/forum/member-wiggs.html[/img] Current - 2020 Range Rover Sport P400e
Thu May 28 2015 9:34pm |
simbad111 Member Since: 10 Feb 2014 Location: wolverhampton Posts: 114 |
search out member called bodsy lives over stafford way, he will sort out for you did mine, phone now connects on entry, top guy, |
Fri May 29 2015 5:28am |
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2792 |
If you get in touch with Bodsy - he does offer other services - upgrades if needed - well worth having IMO 16MY Estoril Blue SVR.............
Fri May 29 2015 6:40am |
Timf Member Since: 27 Feb 2010 Location: East Anglia Posts: 312 |
Mine connects to my Blackberry on first entry to the car in the morning, then won't connect again during the day. Seems as if something needs a sleep before allowing reconnection... any ideas? |
Sun May 31 2015 8:05am |
ive replied to your PM Paul
Mon Jun 01 2015 11:19am |
Thanks Bodsy. Yes, on first use every morning, the phone syncs & the contacts all come up on the display if needed. Then switch the car off, get back in 5 mins later & it doesn't sync |
Mon Jun 01 2015 3:41pm |
I'd start by removing the battery cables and holding them together for 20 seconds to to a Hard reset first. Then see what happens. Failing that, I'd go and check the Blackberry software version. if its not the latest for that phone, then update it. If it is already the latest, then see if you can jump back a version. Bodsys Brake Bible
Mon Jun 01 2015 4:15pm |
Thanks Bodsy, I'll try the battery cable trick & let you know |
Wed Jun 03 2015 3:58pm |
stagfinder Member Since: 17 Dec 2015 Location: Peterborough Posts: 22 |
Hi I have the same problem phone has to be connected every time you open the car I have a samsung s4 with a rrs 06 any help would be great thanks in advance |
Fri Dec 18 2015 12:54am |
gary3306 Member Since: 04 Feb 2015 Location: Northumberland Posts: 208 |
As per the advice above SF, you need an updated bluetooth module. Send Bodsy (Ian) a PM and you'll be sorted |
Fri Dec 18 2015 1:01am |
Yes, I can fix that for you. I'll drop you a PM. Bodsys Brake Bible Software Updates Contact me RRS Timed Heat/Remote kits - Contact me BAS Engine Re-maps/ EGR Blank EuIII and EuIV Clock On The Dash/ SNOTM /3Flash / BT Update /Service Reset/Error Codes read\ Gearbox Reset See it HERE |
Fri Dec 18 2015 7:08am |
fjanssen Member Since: 07 Jul 2012 Location: Dilsen Posts: 18 |
I had the same problem.. After I put a new battery in it, it was okay.. Voltage drops to much when starting the engine.. |
Mon Dec 21 2015 11:08pm |
