Home > Technical > bluetooth
my 1st sport
United Kingdom 2013 Range Rover Sport Supercharged Orkney Grey
bluetooth
Hi
can anybody tell me why i have to pair my iphone every time i turn the igniton off in my 06 sc rrs
thanks paul
Post #463138 Thu May 28 2015 8:28pm
sterling01
Scotland
You need an updated Bluetooth module. Speak to Wiggs [img]http://www.rrsport.co.uk/forum/member-wiggs.html[/img] Current - 2020 Range Rover Sport P400e
Gone - 2014 Range Rover Sport HSE SDV6
Gone - 2017 Audi A8 Sport
Gone - 2007 Range Rover Sport HSE TDV8 - Great car.
Post #463143 Thu May 28 2015 9:34pm
simbad111
search out member called bodsy lives over stafford way, he will sort out for you did mine, phone now connects on entry, top guy,
Post #463152 Fri May 29 2015 5:28am
PEACHY
If you get in touch with Bodsy - he does offer other services - upgrades if needed - well worth having IMO Thumbs Up 16MY Estoril Blue SVR.............
Post #463155 Fri May 29 2015 6:40am
Timf
United Kingdom 2010 Range Rover Sport TDV8 HSE Galway Green
Mine connects to my Blackberry on first entry to the car in the morning, then won't connect again during the day. Seems as if something needs a sleep before allowing reconnection... any ideas? Confused
Post #463315 Sun May 31 2015 8:05am
Bodsy
Site Sponsor
ive replied to your PM Paul Thumbs Up
Tim,
seems unusual. Do you normally get contacts syncing? Could just need a software update or a Blackberry Software update. Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #463432 Mon Jun 01 2015 11:19am
Timf
Thanks Bodsy. Yes, on first use every morning, the phone syncs & the contacts all come up on the display if needed. Then switch the car off, get back in 5 mins later & it doesn't sync Confused
Post #463449 Mon Jun 01 2015 3:41pm
Bodsy
Site Sponsor
I'd start by removing the battery cables and holding them together for 20 seconds to to a Hard reset first. Then see what happens. Failing that, I'd go and check the Blackberry software version. if its not the latest for that phone, then update it. If it is already the latest, then see if you can jump back a version. Thumbs Up Bodsys Brake Bible
See it HERE
Post #463456 Mon Jun 01 2015 4:15pm
Timf
Thanks Bodsy, I'll try the battery cable trick & let you know Wink
Post #463688 Wed Jun 03 2015 3:58pm
stagfinder
England 2006 Range Rover Sport TDV6 HSE Bonatti Grey
Hi I have the same problem phone has to be connected every time you open the car I have a samsung s4 with a rrs 06 any help would be great thanks in advance
Post #482780 Fri Dec 18 2015 12:54am
gary3306
England 2013 Range Rover Sport SDV6 Autobiography Fuji White
As per the advice above SF, you need an updated bluetooth module. Send Bodsy (Ian) a PM and you'll be sorted
Post #482781 Fri Dec 18 2015 1:01am
Bodsy
Site Sponsor
Yes, I can fix that for you. I'll drop you a PM. Thumbs Up Bodsys Brake Bible
See it HERE
Post #482783 Fri Dec 18 2015 7:08am
fjanssen
Belgium 2009 Range Rover Sport TDV8 HSE Stornoway Grey
I had the same problem.. After I put a new battery in it, it was okay.. Voltage drops to much when starting the engine..
Post #483084 Mon Dec 21 2015 11:08pm
