Home > Faults & Fixes > rain sensor not working
sport2007
United Kingdom 2010 Range Rover Sport TDV8 HSE Rimini Red
hi there
my rain sensor dosent work . am I correct in saying that the same sensor operates the auto lights, as these are working ok. would I just need to replace the sensor of is there something I need to try as the auto lights are working fine ? Having said all that how do I remove the rear view mirror and the housing around the sensor on the windscreen?
Any help greatly appreciated.
thanks
phil Sad Sad Sad
Post #479232 Mon Nov 09 2015 7:36pm
tone 123
England 2005 Range Rover Sport Supercharged Java Black
hi. do you have the indicator stalk up one all the time.
Post #479250 Mon Nov 09 2015 9:10pm
gary3306
England 2013 Range Rover Sport SDV6 Autobiography Fuji White
As Tone says, you must move the stalk to position 1 and leave it there for them to operate automatically. If your lights work, there isn't going to be anything wrong with the sensor. What I will say is if your windscreen is minging dirty, that hinders the sensor performance.
Post #479253 Mon Nov 09 2015 9:17pm
sport2007
Range rover sport always clean no issue with dirt or muck covering the sensor . I have had the stalk at the correct position at 1 but no joy, with the lights working its not the sensor is that correct?
thanks
phil
Post #479255 Mon Nov 09 2015 9:23pm
tone 123
have a look from the outside, to see if the sensor is ok. it should be blue purple clear with no blisters misty or white.
Post #479260 Mon Nov 09 2015 9:55pm
sport2007
ok I will have a look tomorrow and come back maybe get a few photos.
thanks
phil Mad Mad
Post #479278 Mon Nov 09 2015 11:09pm
Camelrock
If as you say the auto lights are working then the sensor is ok and your wipers are working in normal and fast speeds then sounds like a faulty switch when position 1.
The only way to tell would be to exchange the switch for another 1 and see if it works.. 2008 G4 RRSport TDV8 current
2009 TDCi 90 current
1994 Dakar current
Post #479281 Mon Nov 09 2015 11:25pm
sport2007
hi there
am back to this old issue cant get auto wipers to work.i have replaced the wiper stalk and just now replaced the sensor itself on the wind screen , still no sign of life. ant one any bright ideas?????? Sad Sad Sad Sad
Post #501808 Thu Jul 28 2016 4:42pm
The rain sensitive wipers can be disabled by altering the CCF. I've done this on my own TDV8 because I hate rain sensitive wipers. If the system has never worked since you bought the vehicle, get the CCF read by someone with a suitable plug-in system. I did mine with my IID Tool. 2012 SDV6 - it's missing a couple of cylinders
Post #501829 Thu Jul 28 2016 9:32pm
sport2007
hi such a long time but what does ccf mean Rolling with laughter
Post #529557 Tue Jul 04 2017 4:32pm
