Home > In Car Electronics > Phone no sound !
Camelrock
Phone no sound !
Hi, I have a fault on the phone, I can connect to the car, phone book etc no problem but when I try to make a call on the the phone and radio display it says dailing but there is no sound then after a minute the car cancels and goes back to the radio.
I know the phone is ok as I've tried it on another RRS which was an 55 plate and it worked fine, mines an 08 any ideas anyone ?
Does the Bluetooth connect to the amp under the drivers seat ? I assume the connections are ok at the head unit as the display is showing phone book etc as said above. 2008 G4 RRSport TDV8 current
2009 TDCi 90 current
1994 Dakar current
Post #463971 Sun Jun 07 2015 5:03pm
Bodsy
Site Sponsor
Blutooth Sits in the boot behind the panel.
I would start with a hard reset. Take the battery connections off and touch the cables together for 10-20 seconds OFF the battery.
Then reconnect and see if it was a software glitch. Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #463981 Sun Jun 07 2015 8:25pm
Camelrock
Hi Bodsy, first thing I tried as well as disconnecting the unit cleaned the connection and checked for backed out wires all seems to be ok 2008 G4 RRSport TDV8 current
1994 Dakar current
Post #463997 Sun Jun 07 2015 10:47pm
scarey
have you tried turning the volume up during the call...
Post #464000 Mon Jun 08 2015 6:54am
Camelrock
Hi scared, it doesn't get as far as a call, there's no ring tone, nothing ! Volume had been one of my thoughts the first time I tried it. 2008 G4 RRSport TDV8 current
1994 Dakar current
Post #464004 Mon Jun 08 2015 7:35am
CRACKA
Australia 2006 Range Rover Sport Supercharged Bonatti Grey
Hi, just wondering how you went as I have a similiar problem. Question
Mine did work and still displays etc but I have lost? all volumne control on Radio, CD and phone. People can hear me but no sound at my end. Sad
Looked at fuses - amp all okay. Does anyone have any Idea ?????
Post #468495 Sat Jul 25 2015 5:21am
CRACKA
Just an update went for a drive and it all came on and worked for a while then stopped again. I saw in another post it could be the amp itself. Mine appears to be under LHS s front seat. Could it be aloose connection under there.
Anyone got any ideas????
Post #468509 Sat Jul 25 2015 9:54am
Camelrock
Is that where the amp is in the sports under the pas (left) seat ?? Because it's under the drivers seat on D3's. Does the phone connect to the amp or to the head unit ?? 2008 G4 RRSport TDV8 current
1994 Dakar current
Post #468510 Sat Jul 25 2015 10:09am
jorn
Belgium 2009 Range Rover Sport TDV6 HSE Stornoway Grey
Same problem here with iphone. I noticed it only happens when its charging (or when the lead is connected to the phone) problem stops when disconnecting the cable.
Post #468595 Sun Jul 26 2015 11:16am
Camelrock
Had it connected to a reader this afternoon and found 2 DTC's on the phone 1 says internal fault in phone module and the other says it needs calibrating. The phone mod will be in the o/s/r next to the access panel I believe ?? 2008 G4 RRSport TDV8 current
1994 Dakar current
Post #468624 Sun Jul 26 2015 5:08pm
