Home > In Car Electronics > Phone no sound ! |
Blutooth Sits in the boot behind the panel.
Sun Jun 07 2015 8:25pm |
Camelrock Member Since: 31 Aug 2013 Location: North Yorkshire Posts: 1003 |
Hi Bodsy, first thing I tried as well as disconnecting the unit cleaned the connection and checked for backed out wires all seems to be ok 2008 G4 RRSport TDV8 current
Sun Jun 07 2015 10:47pm |
scarey Member Since: 07 Jan 2011 Location: in the cloud Posts: 410 |
have you tried turning the volume up during the call... |
Mon Jun 08 2015 6:54am |
Hi scared, it doesn't get as far as a call, there's no ring tone, nothing ! Volume had been one of my thoughts the first time I tried it. 2008 G4 RRSport TDV8 current
Mon Jun 08 2015 7:35am |
CRACKA Member Since: 16 Sep 2014 Location: Hallam Victoria 3803 Posts: 170 |
Hi, just wondering how you went as I have a similiar problem.
Sat Jul 25 2015 5:21am |
Just an update went for a drive and it all came on and worked for a while then stopped again. I saw in another post it could be the amp itself. Mine appears to be under LHS s front seat. Could it be aloose connection under there.
Sat Jul 25 2015 9:54am |
Is that where the amp is in the sports under the pas (left) seat ?? Because it's under the drivers seat on D3's. Does the phone connect to the amp or to the head unit ?? 2008 G4 RRSport TDV8 current
Sat Jul 25 2015 10:09am |
jorn Member Since: 07 Jan 2015 Location: Ypres Posts: 39 |
Same problem here with iphone. I noticed it only happens when its charging (or when the lead is connected to the phone) problem stops when disconnecting the cable. |
Sun Jul 26 2015 11:16am |
Had it connected to a reader this afternoon and found 2 DTC's on the phone 1 says internal fault in phone module and the other says it needs calibrating. The phone mod will be in the o/s/r next to the access panel I believe ?? 2008 G4 RRSport TDV8 current
Sun Jul 26 2015 5:08pm |
