Home > General (L494) > Would you accept this? |
JSR2014 Member Since: 10 Feb 2015 Location: Kent Posts: 341 |
I assume you use the Eco Data side of your L494? If so then you will be aware that there is very little interrogation required, it indicates how hard the throttle is being pushed, how hard the brakes are being used and the top speed.
Tue May 26 2015 5:01pm |
jimbg Member Since: 29 Jan 2013 Location: By the River Dart Posts: 1744 |
I do not have RRS2 (yet ) and find it hard to believe that you can tell so much from a crude scale of 1 to 5?
Tue May 26 2015 5:16pm |
No, sorry maybe I wasn't clear
Tue May 26 2015 5:30pm |
eddkawasaki Member Since: 23 Feb 2015 Location: Lancashire Posts: 93 |
Is it at all possible that his is caused by a software update? I've had some very odd readings on my "distance to empty" figures after software updates during services on my evoque. Like when i went in showing 220 miles remaining and came back out with >500. Could be that some update was applied to the eco software during the service that has skewed the readings hence why you cannot get near them in testing?
Tue May 26 2015 6:09pm |
Humbug Member Since: 01 Aug 2014 Location: East Anglia Posts: 48 |
I could only get near 2.5 on the brakes with repeated emergency stops (off road as the hardest I was prepared to go on road didn't get close). There's no way you could get anywhere near these figures driving in a 30mph limit without caning it.
Tue May 26 2015 7:13pm |
Fletcher Member Since: 28 Jan 2015 Location: Devon Posts: 481 |
Have you got the app thing that you can see the route they took , speed and time to back up your point . Either way for your own peice of mind you need to talk to the dealership . I think there is a lot of "what ifs" that need answering . |
Tue May 26 2015 8:11pm |
Invincible Member Since: 13 Oct 2014 Location: Stigenace Posts: 64 |
JSR2014 considering your original question and the comments made and the replies you have given I truly believe you may have answered your own question. It therefore suggests you are unlikely to change your current position so suggest you go and see the dealership principle and regale the points you have made here to him/her and see where you end up. Obviously please let us all know how you get on. 2015 - HSE Dynamic - Santorini - Stealth Pack 2013 - Evoque - Santorini - Lux Pack 2010 - BMW M3 - Monte Carlo Blue 2007 - BMW 335 - Gun Metal Grey 2004 - BMW Z4 - Gun Metal Grey |
Tue May 26 2015 8:39pm |
Alan61 Member Since: 29 Sep 2011 Location: Edinburgh Posts: 88 |
I guess you need to find a dealership who 'Drive like Miss Daisy' when testing the cars. How do you test the brakes without using them or that the engine is working properly without accelerating?
Tue May 26 2015 9:11pm |
x5pea Member Since: 03 May 2007 Location: Lanarkshire Posts: 2097 |
I drove 11 miles home this evening , half on the motorway the other half through a village at 30mpg then 3miles on a back road. I had to brake sharply to avoid a deer and accelerate to pass a tractor and my"stats" weren't far off yours. |
Tue May 26 2015 10:10pm |
Garage Door Medic Member Since: 02 Feb 2014 Location: North West of UK Posts: 197 |
Get a in car camera, mine records, the journey, the speed, G-forces and conversation in the car. Mine is being picked up for a sevice this week, looking forward to see how they drive it the the dealership MY 13 3.0 SDV6 HSE Black Edition
Tue May 26 2015 10:27pm |
Agreed on this, bear in mind you've (I assume) accelerated onto a slip road (big assumption coming) from a roundabout and gained speed to 70(ish) mph. You've then slammed the brakes on to avoid a collision and overtaken safely but (I again assume) swiftly to get past a tractor. That's not the same readings as the dealer got in less than 2 miles. Now consider these points: The same acceleration force in the S/C will have the car moving substantially quicker. The central symbol is NOT too speed (my mistake) it's speed per gear (so how close to red line) and the dealer didn't have to avoid any deer!! I haven't made my mind up, I just felt a little bit vilified for expressing dismay at how the car was treated. I guess I wanted to hear that they need to drive it hard after the health check is passed, after the service is done to clear carbon deposits or something like that. I was hoping that I was being over sensitive. However, as many have said (yourself included), they had no reason to drive the car, apart from in and out the workshop.... 2014.5 Mariana Black 5.0 Supercharged V8 Autobiography |
Tue May 26 2015 11:37pm |
I'll post the ECO data in the morning for the last 1000 miles I've driven. Includes motorway, fast runs, economy runs and a mix of town driving etc. 2014.5 Mariana Black 5.0 Supercharged V8 Autobiography
Tue May 26 2015 11:41pm |
Why would they be testing the brakes? Car passed the health check at 11:45(ish) and this drive was after 2pm. They didn't even check the tyre pressures so I seriously doubt they'd go as far as the brakes 😜 2014.5 Mariana Black 5.0 Supercharged V8 Autobiography |
Tue May 26 2015 11:43pm |
Farmer Chalk Member Since: 02 May 2015 Location: London Posts: 527 |
If my car was just serviced I would want the dealership to test everything works as it should. This is a skilled mechanic who is testing the systems on your car. How can you determine whether the kick down system in the gearbox is working correctly or if the brakes are pulling up hard and true.
Wed May 27 2015 5:49am |
