Home > General > Range Rover, with the ratchet noise |
Timf Member Since: 27 Feb 2010 Location: East Anglia Posts: 312 |
Wheel bearing? I had a front one go & it was more of a groaning hum... |
Mon May 18 2015 2:54pm |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8844 |
CV joint on half shaft. Probably has (or had at some point) a split gaiter and that's allowed grease out / water in. Had the same thing on mine.
Mon May 18 2015 3:55pm |
Frax Member Since: 07 May 2015 Location: Aberdeenshire Posts: 241 |
Small stone in brake/wheel system or ABS ring.
Mon May 18 2015 6:39pm |
stephen2045 Member Since: 18 May 2015 Location: United Kingdom Posts: 4 |
Hi thanks broke a cv on a disco 3 last year, sure its not that. Thanks, it's a real head scratch,
Mon May 18 2015 8:51pm |
Camelrock Member Since: 31 Aug 2013 Location: North Yorkshire Posts: 1003 |
Since you think it's around the transfer box, have you checked the propshaft joints ? 2008 G4 RRSport TDV8 current
Mon May 18 2015 11:02pm |
ijwebb Member Since: 04 May 2015 Location: United Kingdom Posts: 15 |
by coincidence I was about to post a similar observation about my recently purchased car. Mine is a ratchet sound as well, and sounds louder with the windows closed. I think for me the sounds appears to be coming from the front offside wheel area. I've tried spinning the wheel when jacked up but can't hear anything, but then it's hard to spin it at any real speed. Taking the wheel off and having a look around I can't see anything obvious.
Tue May 19 2015 6:31pm |
alpaca Member Since: 09 Sep 2014 Location: Silicon Valley Posts: 83 |
I had a clicking sound coming from front driver wheel - started at slow speed , increased with speed. Louder when turning one way - shop did not think it was bearing - but I had them change it anyway ... Fixed the problem ... Doesn't sound exactly like your issue - but point was experienced shop couldn't diagnose it as bearing - but since it could be anything else - I chnaged it and that fixed issue |
Fri May 22 2015 8:00am |
Whilst I still don't know what's actually wrong with mine, it seems like changing a wheel bearing is cheap enough for me to do, most likely cheaper than getting a garage to offer an opinion. Does it make sense to change the CV joint whilst I'm at it ? I've read a few places about this also as a possibility. I figure if I'm dismantling things I might as well swap any suspect items whilst I'm at it.
Tue May 26 2015 10:26am |
solved the problem, the plastic clip on top of the fuel tank had broken (the one that holds the cable for the emergency handbrake release) the cable had dropped and was catching the bolts on the prop shaft. It was directly above the prop shaft so you couldn't see it, the only way I worked it out was the bold heads were shiny.
Tue May 26 2015 10:44am |
that's a nice cheap fix - well done for tracking it down.
Tue May 26 2015 12:39pm |
