Home > In Car Electronics > Looking for 12v switched live |
sterling01 Member Since: 19 Apr 2015 Location: Kilmarnock Posts: 127 |
Guys, please excuse the newbie question. I want to install DRL's on my RRS and want them to come on independent of any other lights. Therefore I need a 12v power source that is only live when I switch on the engine. I am not brilliant with electrics, but I can splice a wire and join together. Any ideas where I should be looking around the front of my TDV8?
Mon May 18 2015 5:53pm |
Lost for Words Member Since: 15 Jan 2015 Location: Warminster, Wiltshire Posts: 1477 |
The easiest and least intrusive way is simply to use a voltage sensitive relay like this: http://www.autoelectricsupplies.co.uk/product/925/category/149 Visiting from DISCO3.CO.UK
Mon May 18 2015 6:00pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4855 |
I fitted some DRL lights to a 2009 pre facelift and actually found a switched live in the multi-plug that connects to the headlight unit. I honestly can't remember which wire it was I have a feeling it was Red and Black at the bottom of the plug, unfortunately I have now sold that car so can't go and have a look. They were Phillips Lights which I fitted and came with a Control Unit which when you switched the Sidelights on it Dimmed the DRL's.
Mon May 18 2015 6:55pm |
simbad111 Member Since: 10 Feb 2014 Location: wolverhampton Posts: 114 |
try this link may help you http://www.rrsport.co.uk/forum/post385109.html#385109, |
Mon May 18 2015 7:28pm |
Plenty of ignition lives around (Another here: http://www.disco3.co.uk/gallery/displayima...amp;pos=39), but the OP was asking for an engine live.
Tue May 19 2015 10:21am |
Many thanks guys for all your help. Will post pics when the job is done.
Tue May 19 2015 12:26pm |
tanloverluke Member Since: 19 Mar 2013 Location: Honiton Posts: 917 |
whatever you do don't piggy back off of the fuel pump fuse.
Tue May 19 2015 1:49pm |
CRACKA Member Since: 16 Sep 2014 Location: Hallam Victoria 3803 Posts: 170 |
I fitted DRL's to my 06 RRS and picked up the wiring at a connection leading to the headlights. Like COL said.
Mon Jun 08 2015 8:37am |
