Home > Maintenance & Modifications > Carbon Fibre Repair?
cocobench
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Fuji White
Just a quick question, i have a CF bonnet that i want spraying fuji white. i brought the bonnet with a "chip" in the CF which has a spider like formation of lines approx 2inc in length. Can this be repaired or will it be good to paint over?
thanks
 MY 11 TDV6 Fuji White Onyx
Gone-
64 E 220 cdi saloon
63 E250 cdi Coupe
62 Slk 250 Cdi
11 E 250 cdi Cab
08 BMW M3
08 ML420 Cdi
07 Cooper S JcW
04 R32
Post #456161 Tue Mar 17 2015 7:17am
Paddi
Not a common modification that - are you building a lightweight special? Rolling with laughter
I've repaired a few glassfibre boat hulls/decks where the construction is similar but using glassfibre matt and epoxy resin lay-up.
Carbon fibre (or composite) panels are made in a similar way but using carbon fibre matt and a resin lay-up or vacuum moulding.
The damage must be repaired before painting or the cracks will just re-appear.
The repair technique is to grind out the damaged section until the cracks are no longer visible and then add a layer of resin, a small piece of matt cut to the shape of the damaged part , then another layer of resin followed by a slightly larger piece of matt and so on until the ground out hollow is almost level with the surface. Then allow to cure before finishing with a gel coat filler and sanding and priming.
Unless you enjoy that sort of thing (and there aren't many that do!) - best left to an expert. Try a specialist racing yacht builder/repairer as they fabricate parts in carbon fibre all the time. 2008 MY Java Black TDV8 HSE
Post #456463 Thu Mar 19 2015 4:42pm
