Home > Technical > Timed climate |
fkarim Member Since: 14 Apr 2012 Location: London Posts: 2216 |
Were you stationary when you saw the option greyed out? It is disabled while driving so you don't get distracted trying to set the timer.
Tue Jan 20 2015 10:26am |
jeffhunt Member Since: 19 Oct 2014 Location: Hayling Island Posts: 83 |
I had a similar problem when I did mine.
Tue Jan 20 2015 1:54pm |
myfirstrrs Member Since: 20 Jan 2014 Location: Lancashire Posts: 433 |
Thanks fkarim and jeffhunt, all this helps me to learn.
Tue Jan 20 2015 1:56pm |
I know that the manual heat options are greyed out if you turn the ignition on, you have to leave the start button alone, and just press the radio on button, they then appear (un-greyed out).
Tue Jan 20 2015 6:17pm |
Spot on, I got the same information from GAP about 30 minutes ago but thanks anyway. The reason that I could see it in the menu sometimes and not at others is because sometimes I had the ignition on.
Tue Jan 20 2015 7:34pm |
You can use the service function of the IID Tool for the FBH from the AHCM-auxillary heater control
Tue Jan 20 2015 7:47pm |
It does, a lot. I'm on it. |
Tue Jan 20 2015 7:49pm |
Glad to be of help,
Tue Jan 20 2015 7:54pm |
OK, it appears that my FBH is not working, the IID Tool shows me fault code:
Tue Jan 20 2015 9:38pm |
Sorry to hear that its FUBAR'd,
Tue Jan 20 2015 9:59pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4352 |
Or even has a spare FBH in the shed |
Tue Jan 20 2015 10:22pm |
Now you won't give me the easy fix solution - just kidding.
Tue Jan 20 2015 10:25pm |
There is
Tue Jan 20 2015 10:34pm |
I mean is there an easy fix. Not "do you have a spare FBH". 😄 |
Tue Jan 20 2015 10:50pm |
