Home > Technical > Timed climate |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4335 |
Ah. Never had to look at one with an internal module failure before...
Tue Jan 20 2015 11:05pm |
jeffhunt Member Since: 19 Oct 2014 Location: Hayling Island Posts: 83 |
Might be clutching at straws, but have you connected the IIDTool again and checked that the dealers haven't reset the CCF so it is only showing FBH fitted & Park Heater not?
Sun Feb 08 2015 10:18am |
myfirstrrs Member Since: 20 Jan 2014 Location: Lancashire Posts: 433 |
Thanks jeffhunt, I checked with the IID Tool and all is still as I had set it. The timed heating screen still appears OK and I can set the timer, it just seems to work for only a few minutes. Driving me mad now. |
Sun Feb 08 2015 1:27pm |
UPDATE and SUCCESS!
Sat Feb 21 2015 5:51pm |
Minshy Member Since: 06 Jun 2014 Location: Mottram Posts: 48 |
Just had mine fitted last week.
Sun Feb 22 2015 8:29pm |
Hi Minshy, I have been leaving mine set at about 21 degrees and on "auto." Battery needs to be OK and enough diesel.
Sun Feb 22 2015 8:51pm |
Thanks for the response at least I have an idea what to expect next time I switch it on,
Sun Feb 22 2015 9:24pm |
kljw Member Since: 01 Aug 2006 Location: Edinburgh Posts: 117 |
myfirsrtrrs
Wed May 13 2015 7:30pm |
Keith,
Wed May 13 2015 7:38pm |
Steve
Wed May 13 2015 8:01pm |
Are you sure it's the aux heater? The position changed on the RRS2, tucked away left hand side at the back as you look at the engine bay from the front.
Wed May 13 2015 8:05pm |
Hi
Fri May 15 2015 1:09pm |
If it's fitted, it can be enabled |
Fri May 15 2015 7:53pm |
dc44back Member Since: 29 May 2018 Location: London Posts: 151 |
How does it know what temperature to set at?
Tue Jan 16 2024 6:02pm |
