Home > General > New here and to Range Rovers! |
All sounds like complete rubbish. Find a proper specialist. 2008 MY Java Black TDV8 HSE
Fri Jan 16 2015 3:03pm |
Lost for Words Member Since: 15 Jan 2015 Location: Warminster, Wiltshire Posts: 1477 |
Before fully replacing the compressor, it may be worth checking if the air dryer is blocked. You can either take it apart and microwave/replace the silica gel inside or just buy a new dryer. http://www.advancedfactors.co.uk/vub504700-air-dryer-5191-p.asp
Fri Jan 16 2015 3:27pm |
FatJoe Member Since: 13 Dec 2014 Location: Staffordshire Posts: 259 |
Hold on, didnt you say the suspension was working all ok now? Why are you looking to replace it? Drive it till it breaks. Also £2,400 WTF. They are playing on your inexperience with these machines.
Fri Jan 16 2015 8:52pm |
May be worth a look: http://www.disco3.co.uk/forum/topic91299.html Visiting from DISCO3.CO.UK
Fri Jan 16 2015 8:58pm |
a3lkx Member Since: 10 Jan 2015 Location: liverpool Posts: 19 |
Yeah suspension works fine now but he said the compressor is weak, needs lower arms on front, electric handbrake fault and air bag fault along with a service £2400. Air bag fault is the sensors in the seat or seat belt. Parking brake is intermittent signal or module fault, Both of which I can live with. Ill have a look at that disco thread
Fri Jan 16 2015 9:37pm |
The air bag light, not sure on these beasts but can you not unplug the connector and plug it back in? On old cars I had, some kind of static built up and sometimes would throw the airbag light on. Happened in some cars I had if I remember rightly. Plug was usually under passengerseat but not sure on these motors.
Fri Jan 16 2015 10:52pm |
Seriously, try this. It's a known issue (and one I suffer from too) - the drivers seatbelt pre-tensioner cable gets a bit stretched/disrupted when the seat is moved. Visiting from DISCO3.CO.UK 2006 Discovery 3 TDV6 Auto HSE Zambezi Silver |
Sat Jan 17 2015 10:18am |
Cheers guys
Tue Jan 20 2015 9:12pm |
Service schedule here: http://www.rrsport.co.uk/gallery/albums/us...0miles.pdf
Wed Jan 21 2015 10:31am |
Wed Jan 21 2015 5:35pm |
