Home > Maintenance & Modifications > winter is here, drl's to be installed |
TrevG Member Since: 14 Aug 2012 Location: Kent Posts: 48 |
I used the ignition live as flydrive see thread..
Wed Nov 05 2014 2:33pm |
tanloverluke Member Since: 19 Mar 2013 Location: Honiton Posts: 917 |
agreed, very strange! I asked the LR teccie and he said no way would that cause a problem. But the garage saw that with the drl's on the pump stopped working. Maybe it's a sign that the pump is on its way out, we'll see.
Wed Nov 05 2014 2:50pm |
TrevG, you replied whilst I was writing my previous post. All credit to you my friend!!! Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project. DONE: Meduza front bumper, AB rear bumper, AB tailpipes, calipers repainted, rear upper tailgate upgrade, side steps, AB front grille, AB side vents, rear LED lights, clear side repeaters, integrated daytime running lights, LED headlights. TO DO: color code sills and pillars. |
Paulcp Member Since: 18 Apr 2013 Location: Suffolk Posts: 327 |
I did look at the spare relay option from the same thread, but on my Black Edn there is no live in the spare relay slots
Wed Nov 05 2014 3:50pm |
Paul, do you have the dormant wiring loom by the front radiator? Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project.
Wed Nov 05 2014 8:04pm |
TBH I can't remember, will check tomorrow
Wed Nov 05 2014 8:53pm |
simbad111 Member Since: 10 Feb 2014 Location: wolverhampton Posts: 114 |
Hi guys could anyone help with a little info regarding wiring of drl rings that I have purchased, the rings have black red and white cable attached, I have also purchased a auto drl switch which also has red black cables which connect to the rings the switch also has a white cable, my question is where do I connect both white wires to, may be simple answer but rather be safe that sorry, |
Wed Dec 10 2014 8:42pm |
This may help..
Wed Dec 10 2014 10:13pm |
Yep, red to the live of the battery, black to the chassis, and white to either the live of the headlights or the fuse box. If you have only 3 wires I would have though the 3rd white cable goes to the fuse box, otherwise your lights would be on permanently. any instructions with them? Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project. DONE: Meduza front bumper, AB rear bumper, AB tailpipes, calipers repainted, rear upper tailgate upgrade, side steps, AB front grille, AB side vents, rear LED lights, clear side repeaters, integrated daytime running lights, LED headlights. TO DO: color code sills and pillars. |
Thu Dec 11 2014 10:52am |
After many question and many post read I finally took the plunge and decided to install led drl rings on my RRS, the only scary part was putting lights into the oven but little and often rather than long period in the oven seems to work for me, I searched for ages to find the correct rings for me 5 led rings, each to there own though, I painted the internals satin black and changed the amber side refactors to clear ones, I am really pleased with the outcome,
Sun Dec 14 2014 1:31pm |
mad-dafty Member Since: 28 Oct 2013 Location: Glasgow Posts: 298 |
Nice job mate, love the clear reflector. 2010 RRS TDV6 3.0 Autobiography - Stornoway Grey
Sun Dec 14 2014 3:40pm |
designboy Member Since: 03 Feb 2014 Location: whitehead co antrim Posts: 338 |
Can you take a front only shot off this too? looks ace. |
Sun Feb 01 2015 7:16pm |
the reflector looks ace! how did you make it? I was looking high and low for a sheet of refective plastic.
Mon Feb 02 2015 12:12pm |
I made mine from a fluorescent light diffuser, about £7 from Wickes. |
Mon Feb 02 2015 1:33pm |
