Home > General > Detachable towbar won't fit |
sagalout Member Since: 26 Feb 2013 Location: Harrogate Posts: 128 |
Does anyone know if the LR detachable towbar is the same across all models? I purchased on on ebay which was listed as D3/D4 and RR Sport compatible, but the metal lug that goes in and out as you turn the handle won't go in far enough to seat in the receiving bracket. I'm wondering if its the wrong towbar or somehow faulty?
Wed Jun 18 2014 10:17pm |
codfather Member Since: 13 Feb 2010 Location: ayr Posts: 1171 |
Yes it should retract, looks like it is seized. Get some WD40 in the joints and see if that helps. The small pin at the top triggers the bigger bolt shown to lock into place
Wed Jun 18 2014 10:38pm |
Thanks for that - just gave it a good dowsing in wd40 and its retracting fully now |
Wed Jun 18 2014 10:53pm |
Now it's all free, take it off again and give it the same good dousing in spray grease, otherwise it's a real pita to get off again. Bodsys Brake Bible
Wed Jun 18 2014 11:54pm |
tonytiger Member Since: 14 Sep 2013 Location: St.Neots. Cambs Posts: 308 |
When fitted are they rock solid?? Or is there any movement?? Thx tt 2010 TDV8 Bali Blue........ "Alive Tuned"
Sun Jun 22 2014 5:17pm |
martyn05 Member Since: 13 Feb 2014 Location: Derby Posts: 324 |
solid 2006 RRS SC Bonatti Grey (the 55th car/van I have owned)
Sun Jun 22 2014 5:18pm |
Ollyhall Member Since: 30 Aug 2015 Location: Portsmouth Posts: 13 |
I'm having the same problem, do you need the keys to fit a tow bar? I'm wondering if mine has come with the wrong keys some how? |
Thu Sep 03 2015 5:56pm |
Yes, you must have the key. Bodsys Brake Bible
Thu Sep 03 2015 6:20pm |
lamb190 Member Since: 12 Jun 2015 Location: bristol Posts: 80 |
MAKE SURE YOU "PULL" the green lever as well as twist it! (you need key in and turned) |
Thu Sep 03 2015 6:31pm |
Lamb you just saved me from launching the thing down the road! Wondered what that arrow ment hahaha thanks buddy |
Thu Sep 03 2015 6:42pm |
Bladeboy Member Since: 17 Sep 2013 Location: Benson Posts: 522 |
On a similar vain, my key won't come out when it's fitted. Apart from making it very nickable, is it safe to tow with the key in?
Thu Sep 03 2015 7:05pm |
im glad i could help..... from experience see! as i had the same issue!
Thu Sep 03 2015 7:23pm |
Mines all fitted now, I used wd40 on all the parts, and bought some nice thick grease to lube the hole and shaft that why removal should be easier, key popped out fine after this it is worrying tho as I'm picking a new caravan up Saturday hope she don't fall offlol |
Thu Sep 03 2015 7:34pm |
im sure you can tow in confidence.
Thu Sep 03 2015 7:46pm |
