Home > General > Detachable towbar won't fit
sagalout
Does anyone know if the LR detachable towbar is the same across all models? I purchased on on ebay which was listed as D3/D4 and RR Sport compatible, but the metal lug that goes in and out as you turn the handle won't go in far enough to seat in the receiving bracket. I'm wondering if its the wrong towbar or somehow faulty?
Here are a couple of pics to explain. Can anyone else with the towbar confirm if the lug should retract all the way?
photo 2 by sagalout, on Flickr
photo 1 by sagalout, on Flickr
Post #427599 Wed Jun 18 2014 10:17pm
codfather
Scotland 2010 Range Rover Sport 3.0 TDV6 SE Santorini Black
Yes it should retract, looks like it is seized. Get some WD40 in the joints and see if that helps. The small pin at the top triggers the bigger bolt shown to lock into place
Hope that helps
Dave MY10 TDV6 SE (debadged Wink ), Santorini Black, Flappy paddles, Privacy Glass, 20" Stormers, Mudflaps!
Gone: a comprehensive list of imprezas and a Merc ML AMG
Post #427602 Wed Jun 18 2014 10:38pm
sagalout
Thanks for that - just gave it a good dowsing in wd40 and its retracting fully now Smile
Post #427607 Wed Jun 18 2014 10:53pm
Bodsy
Site Sponsor
Now it's all free, take it off again and give it the same good dousing in spray grease, otherwise it's a real pita to get off again. Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #427612 Wed Jun 18 2014 11:54pm
tonytiger
England 2010 Range Rover Sport TDV8 HSE Bali Blue
When fitted are they rock solid?? Or is there any movement?? Thx tt 2010 TDV8 Bali Blue........ "Alive Tuned"
[URL=][/URL]
Post #427979 Sun Jun 22 2014 5:17pm
martyn05
solid 2006 RRS SC Bonatti Grey (the 55th car/van I have owned)
2005 GSX 1400 K5
Post #427980 Sun Jun 22 2014 5:18pm
gogsy1956
after you've finished with the WD40 get the weedkiller out Laughing 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #427985 Sun Jun 22 2014 6:22pm
Ollyhall
I'm having the same problem, do you need the keys to fit a tow bar? I'm wondering if mine has come with the wrong keys some how?
Post #471874 Thu Sep 03 2015 5:56pm
Bodsy
Site Sponsor
Yes, you must have the key. Thumbs Up Bodsys Brake Bible
See it HERE
Post #471876 Thu Sep 03 2015 6:20pm
lamb190
United Kingdom 2006 Range Rover Sport 4.4 V8 HSE Rimini Red
MAKE SURE YOU "PULL" the green lever as well as twist it! (you need key in and turned)
Post #471878 Thu Sep 03 2015 6:31pm
Ollyhall
Lamb you just saved me from launching the thing down the road! Wondered what that arrow ment hahaha thanks buddy
Post #471879 Thu Sep 03 2015 6:42pm
Bladeboy
England 2005 Range Rover Sport TDV6 HSE Siberian Silver
On a similar vain, my key won't come out when it's fitted. Apart from making it very nickable, is it safe to tow with the key in?
Hoping the answers yes as I've just done quite a bit of towing with it!
Post #471885 Thu Sep 03 2015 7:05pm
lamb190
im glad i could help..... from experience see! as i had the same issue!
the key should come out once tow bar is fitted and key is then rotated into lock position. key stays in towbar when its removed. Thumbs Up i
Post #471887 Thu Sep 03 2015 7:23pm
Ollyhall
Mines all fitted now, I used wd40 on all the parts, and bought some nice thick grease to lube the hole and shaft that why removal should be easier, key popped out fine after this it is worrying tho as I'm picking a new caravan up Saturday hope she don't fall offlol
Post #471889 Thu Sep 03 2015 7:34pm
lamb190
im sure you can tow in confidence.
make sure you keep the tow bar cap fitted in the hole for the towbar when its not in use. stops crud and salt getting up there. Cool
Post #471890 Thu Sep 03 2015 7:46pm
