Home > Technical > Some Electrical Gremlins |
Stuart Member Since: 18 Oct 2013 Location: Manchester Posts: 581 |
I have had the car for months, and not an electrical gremlin to report until the last few days.
Fri Apr 18 2014 2:10pm |
Yes, I had park brake fault as well! And I never use it. |
Fri Apr 18 2014 2:24pm |
RRS Daz Member Since: 23 Jan 2012 Location: Yorkshire Posts: 797 |
I thought the park brake saying was use it or lose it ?? |
Fri Apr 18 2014 8:24pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4338 |
Battery, brake pedal switch, and/or bulbs
Fri Apr 18 2014 8:40pm |
No bulbs are blown, and none have been replaced recently. How might one differentiate between the brake pedal switch and the battery? Or should I just replace the battery on spec first and see what occurs? Are we still liking these ones (identified from other topics)? I wont buy a main dealer one - not into paying extra ££'s for an LR badge. |
Fri Apr 18 2014 8:59pm |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8849 |
One could stick a meter across the battery and see what you've got. Then start it and see what you get. Then check it again after a few minutes to see what it's showing. Alternatively, the brake switch is described as a simple and cheap replacement so might be worth a try. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Sat Apr 19 2014 12:50am |
I take the view that the shoes are relatively easy to change whereas the EPB module looks to be a body off (or at least rear raised) job to replace. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Sat Apr 19 2014 12:52am |
I did the multimeter test on my battery and it got good readings when standing and running, I then had the battery tested on a computer which stated the battery was knackered.
Sat Apr 19 2014 7:49am |
Just to wake this one up again........
Sat May 10 2014 10:47pm |
BKHK Member Since: 05 May 2008 Location: Perth Posts: 1936 |
Jus to replace the battery, then you can eliminate it as the suspect. If it's not the battery today, it will need replacing soon so I would advise doing it anyway. |
Sat May 10 2014 11:55pm |
I think you want something like 12.5V when stood (less than 12V isn't great but could just be the result of short runs, less than 11.5V and you're in trouble), it goes up to about 13.5V just after starting the engine and then up to about 14.5V during constant running. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Sun May 11 2014 7:35am |
I had a play with this today with the voltmeter at work, I am getting about 12.5v not running, and around 14.5 when running as expected.
Wed May 21 2014 12:54am |
Just for completeness, and to help random surfers, searching the archives here tells me this is unconnected with the faults. The stereo shifts into low power mode when the engine is off. It wont go above a certain volume etc, and when you try, it throws up that message. The kids are always clowning with the stereo and seat warmers, etc. What I saw was a result of small sticky fingers constantly tampering. I found this out the other day waiting with the engine off, when the stereo wouldnt turn up and I saw the same message again. So that was a red herring in relation to the faults mentioned. |
Wed May 21 2014 1:07am |
Unless the alternator/battery is not giving enough power out
Wed May 21 2014 6:31am |
